SpeedFactory Map Sensor
Old 01-29-2016, 08:05 AM
sdbee84's Avatar
Default SpeedFactory Map Sensor
Hi HT,
I bought a speedfactory map sensor 3 years ago. I can't remember what I bought. Don't know If it is a 3 or 4 bar map sensor. There is nothing on it that would tell what it is. Would the tuner need to know what it is? I won't ever be over 25 psi, can the tuner set the map sensor to 3 bar in Hondata and will it still read? Not sure, please help. Thanks!
Old 01-29-2016, 08:50 AM
Turbo-LS's Avatar
Default Re: SpeedFactory Map Sensor
Pretty sure they only sell 4 bar
Old 01-31-2016, 04:54 AM
drmix's Avatar
Looks like they offered a 3, 4, and 7 bar map in the past.
https://honda-tech.com/forced-induct...ipped-2723388/
Let your tuner know that you are unsure what bar your map is. If you have a boost gauge you should be able to compare what the gauge says versus what your map sensor is reading and set it up that way. Map sensors are very important with how a vehicle operates and you will definitely need to figure it out in order for your car to run properly.
Old 01-31-2016, 11:20 AM
I never narc'd on nobody!
NotARaCist's Avatar
You can also just use compressed air to test the MAP sensor and see what it is. Apply 35 PSI to the sensor, see what it reads.
young geezer
08-01-2009 12:44 PM
ekk41
10-24-2007 05:28 PM
KRWTEK1
05-28-2007 12:32 AM
turbolshatch
02-02-2006 06:06 AM
TurboGS-R
08-18-2005 01:28 PM
Quick Reply: SpeedFactory Map Sensor
