***The Official Nitrous Thread***
#5051
I like the tuna here
Re: ***The Official Nitrous Thread***
Wizards of NOS have nitrous discharge tubes as well as nozzles, and they seem to be the only ones to offer discharge tubes. (Which is why it's super difficult to find anything online related to them.) In theory, the less phase change you have in the liquid nitrous, the better. Things like 90 degree bends, diameter changes, ect, can all negatively effect flow. A discharge tube looks to be similar to an annular nozzle in that the nitrous has a straight shot to the port. But where annular nozzles have an internal orifice to change the spray pattern, discharge tubes do not.
Discharge tubes:
I guess I was just wondering if anyone has ever used them or something similar. I've seen similar things on ITB setups where it's just a U bend into the ITB.
Discharge tubes:
#5052
ah i understand, i saw that style on xenocrons nitrous k20 project car from years ago. i think those would be benficial if you were spraying a really large shot but for a street application i think youll be fine with regular nozzle kit. just a guess tho.
#5053
I am a newb to nitrous but have recently acquired a 13:1 lsv forged rods and pistons engine. I was wanting to put a large shot of nitrous on it and was wondering what precautions to take to do it. Or even if it is realistic. I was hoping to put a 150 to 200 shot on it direct port (also currently owned). Is the compression going to hinder how large of a shot I can put on it or because I have forged internals am I safe to run such a large shot? I have had alot of conflicting information and understand a tune will be needed regardless of the size of the shot. Thank you in advance for any help given and please do not flame for I am only here to further my knowledge on this and many other issues to come. Thank you.
#5054
#5055
Your compression ratio will be fine if youre running good fuel. Pump e85 at a minimum - c85, e98, q16, or methanol if you have the money. Fuel is priority with a nitrous system, consistency and quality are key to keeping the engine alive. Dry would be ideal in my opinion, let your engine management do the extra fueling. 150 should be just fine, 200 would be pushing it on stock sleeves, but if you and your tuner are comfortable with it, go for it. Youre gonna need really cold plugs too, 8s at a minimum, 9s would be ideal.
#5056
Hey thank you for your help and information. I have already thought about going e85 so now that you have mentioned it I will go that route. By any chance does anyone know an approximate hp the stock sleeves become an issue and preventative measures other than sleeving. Thank you again for the response, knowledge, and advice.
#5057
Hi all
im just speculating and doing more research here for one of my longtime nitrous build
i have some questions
i have a b series motor
i have a nitrous kit wet nos 75 shot
everything was suppose to be tapped at the cold air intake bla bla the normal
but I got to thinking more fun for direct port
ive read direct port you drill each runner 1/8 npt for fogged size correct??
now I have a edelbrock performer x intake manifold
it has 1/8 npt’s and 3/8npt’s predrill tapped from factory.
runner 2 has a 3/8 npt and a runner 3 has a 3/8 npt
i can step those down to 1/8 npt
then I was wondering cheap version direct port
install my single frogger nozzle kit 1/8 npt into my intake manifold directly
Cheap man direct port ?? Or just stupid ??
any thoughts and input?
im just window brainstorming.
i understand. Running doing the cold air intake jet way cyl1 usually gets the most nos creating unbalance
my way putting the single frogger nitrous jet directly into intake manifold. The runner 2 or runner 3 has best center located bung theyre 3/8 npt I can step down to 1/8 npt screw in my nitrous jet just maybe angle it towards back of intake manifold facing firewall so it even balance out spray a little more?
what u guys think lol weird idea poor man directing hahah
ps this is my turbo setup
i have another setup which is nitrous
and want to buy Another edelbrock performer x for b16 for my nitrous build
(idk why I have a thing for the edelbrock performer x im’s street cars ya no lol)
#5058
A single nozzle must go in the intake tube before the throttle body inlet/blade. Direct port nozzles must be installed into the top or bottom of each intake runner and NOT at the back of the Plenum as you have described. You decide which.
WeekH22#2
10-17-2006 11:50 AM
degradated
01-03-2002 11:16 PM
