VAFCs worth it?
Old Sep 3, 2008 | 12:46 AM
  #26
GTlvr82's Avatar
Default Re: (EK Josh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK Josh &raquo;</TD></TR><TR><TD CLASS="quote">So, you want a VAFC so you can move your VTEC engagement around at will with no rhyme or reason as to where you're making it engage? k.</TD></TR></TABLE>
No the other guy does....I've had the same one in a box for forever...so I installed it cuz I was bored....I basically use it as a monitoring system for the battery.
Old Sep 3, 2008 | 03:02 AM
  #27
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote"> I just got my 4th pube, and boner
is that a REAL type R?</TD></TR></TABLE>
lol, there's always a point not to cross in a conversation. I believe the boner comment hit that line
Old Sep 3, 2008 | 03:20 AM
  #28
Jvs10's Avatar
Default Re: (Import_Fan)
Let me get this straight..you're going to buy a fuel controller so you can run vtec? Since you're on OBD0, wouldn't it be more cost efficient to get a ZC ECU? Even a z6 ecu and conversion harness wouldn't be as much as a VAFC and you wouldn't have to reset it every week.
Old Sep 3, 2008 | 03:28 AM
  #29
Import_Fan's Avatar
Default Re: (Jvs10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jvs10 &raquo;</TD></TR><TR><TD CLASS="quote">Let me get this straight..you're going to buy a fuel controller so you can run vtec? Since you're on OBD0, wouldn't it be more cost efficient to get a ZC ECU? Even a z6 ecu and conversion harness wouldn't be as much as a VAFC and you wouldn't have to reset it every week.</TD></TR></TABLE>
Don't bring your logic and reasonable solutions into this thread.
Old Sep 3, 2008 | 03:30 AM
  #30
downeyballz's Avatar
Default Re: (Jvs10)
i was intrestd in a vafc for a little wile as a quick solution to get my lsvtec running, but then i decided theres too many free tunning programs out there.
Old Sep 3, 2008 | 03:35 AM
  #31
Jvs10's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_Fan &raquo;</TD></TR><TR><TD CLASS="quote">
Don't bring your logic and reasonable solutions into this thread. </TD></TR></TABLE>
True.
OP, here's what you do. First, get an ECU case. Next, fill it with ham and plug it in. While your car may not run, it will be filled by the delightful scent of ham..which is a win in my book
Old Sep 3, 2008 | 07:51 AM
  #32
Radim's Avatar
Default Re: (GTlvr82)
I'm getting a VAFC2 for $100 so it would be cheaper than the ECU+Conversion Harness.
Old Sep 3, 2008 | 08:33 AM
  #33
EK Josh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 &raquo;</TD></TR><TR><TD CLASS="quote">No the other guy does....I've had the same one in a box for forever...so I installed it cuz I was bored....I basically use it as a monitoring system for the battery.</TD></TR></TABLE>
I think I might have replied to your post, but my comment was geared towards the OP.
OP: if you're getting a VAFC so you look "cool" and you just want to move your VTEC around for no apparent reason then... Do you even have any mods to warrant such a change? A VAFC is a tuning device used to adjust the air/fuel ratio along with adjusting the VTEC engagement. Although, I suppose if you were really concerned with actually tuning the car and not just being a cool kid with a flashy toy you'd be asking about Chrome, Uberdata, or if you had the money, Hondata.
Old Sep 3, 2008 | 08:55 AM
  #34
98vtec's Avatar
moderator emeritus
locked
Voodooboy520
Honda S2000
Sep 29, 2008 10:14 AM
vteclife
Jan 3, 2008 08:49 AM
philkehn
10
Oct 3, 2006 11:55 AM
Civiclaker
Sep 17, 2003 11:05 AM
USDM 4G VTEC
Apr 30, 2002 11:48 PM
