tuning, obd2, emissions - how's it done?
Old May 6, 2008 | 08:10 AM
bungalo101's Avatar
Default tuning, obd2, emissions - how's it done?
So I'm revisiting the same problem I have yet to find a great answer to. Passing emissions and tuning an OBD 2 vehicle. Figured I would find out how ppl here on honda-tech are doing it. I know the right way to get the tuning done would be down convert to OBD1, chipped ECU, and chrome/hondata/neptune/etc. but that's just not an option when the time comes for emissions (yearly here in PA).
Additionally I know that most piggy back systems are inadequate for proper tuning. So what do you guys recommend? How are others passing emissions? I need something that will allow me to at LEAST tune for compensation of lower compression pistons.
Preferably I would like to not have to rip off turbo, manifold, injectors, etc. each year. So far the best idea I have is to run OBD 1 during the year and pick up something like the AEM FIC for passing emissions. Pull the wastegate spring and just have a light tune for larger injectors and lower compression.
Comments, suggestions?
Old May 9, 2008 | 12:09 PM
bungalo101's Avatar
Default Re: tuning, obd2, emissions - how's it done? (bungalo101)
Anyone?
Old May 9, 2008 | 03:46 PM
pumafeet10's Avatar
id like to know as well, looking at the f/ic but im not sure which would be cheaper to do or more effective?
Old May 18, 2008 | 07:55 PM
SOHFAST94's Avatar
Basically what I do since I'm a factory calibrator is just emulate the test and make it pass using a 5 gas analyzer. I know that's not much help but that's all you get.
Old Jun 1, 2008 | 06:09 PM
AFAccord's Avatar
Default Re: tuning, obd2, emissions - how's it done? (SOHFAST94)
Honestly, when I add OBD2, turbo, and emissions, I get a blank...
Old Jun 1, 2008 | 06:51 PM
norconex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bungalo101 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone?</TD></TR></TABLE>
All you can do is convert back once a year, keep your stock Injectors, ECU and Map sensor, keep it plug and play when you put on your new stuff. It will take you about 1-2 hours total to unconvert and convert back...plus the drive to and from the inspection place.
Here's some things you can use to help keep it all plug and play.
- OBD2 Injector Harness
- Conversion Harness
- Map Sensor
PM me and I'll give you specific links to where you can find that stuff...
- Chris
nycgsr
Apr 23, 2017 07:09 PM
integrawow
Engine Management and Tuning
Dec 27, 2008 09:07 AM
bungalo101
May 16, 2008 10:29 AM
97dxnut
May 11, 2004 02:35 PM
jolt-tsp
Oct 14, 2003 12:43 PM
