Tuning obd2 b18c-r
Old Mar 12, 2013 | 06:12 PM
Eg->sean's Avatar
Default Tuning obd2 b18c-r
I'm currently running a 99 b18c type r, obd2 motor. I wanted to know what is the best route for tuning? Is there a good way to tune with an obd2 ecu or should I convert to obd1 and run Hondata? If I converted to obd1, what is involved to do it properly?
Old Mar 12, 2013 | 06:22 PM
Eg->sean's Avatar
Default Re: Tuning obd2 b18c-r
Sorry, I should have also mentioned that the motor is in a 92 eg hatch. I'm using an obd1 to obd2 conversion harness to use the P73 ecu.
Old Mar 12, 2013 | 09:16 PM
mtber's Avatar
Read http://www.phearable.net/tech/efibeginnerguide.html
Using an obd1 ecu solution would be ideal for you.
Call us if you have any questions after reading the efi intro guide at 1-888-236-9831 extension 1
barraea
Engine Management and Tuning
Feb 1, 2016 09:33 PM
thanh4o8
May 16, 2008 11:10 AM
92civic_si
16
May 6, 2004 02:50 PM
D16Z6racing
12
Jul 26, 2002 02:15 PM
hatchy
Mar 31, 2002 08:24 AM
