s300 Vss Issue.
My ecu isn't showing a value for the vss, although my speedo is working fine. I replaced the vss during my engine build since it was messed up before. what could be the problem?
Thanks in advance!
Thanks in advance!
Probably a wiring problem. The VSS signal splits and goes to the dash and the ECU. The ECU is not getting a signal.
Ok, so i should just follow the wiring and looks for a problem?
I need to take it to get tuned, but i cant get tuned for boost by gear if my ecu isn't getting a vss signal lol.
Thanks for the help.
duh blacksheep
18
Jul 23, 2005 05:41 PM
