check engine light...
Old Mar 23, 2003 | 10:22 AM
markD.'s Avatar
OMG it'Z McFLY!
Default check engine light...
hey guys i need some help or opinions on whats going on wit my 99 Integra. i was driving it today and my check engine light started to flash. the car was lugging when i shifted into every gear. it idles very low and makes a "ticking" sound. also when i go to 2500 rpms it makes a kind of humming noise that sounds strange. what could be the problem?
btw, all liquid levels look fine. maybe could use a tad bit more oil..
Old Mar 23, 2003 | 11:05 AM
markD.'s Avatar
OMG it'Z McFLY!
Default Re: check engine light... (MaRkDmB7676)
help please??
Old Mar 23, 2003 | 11:11 AM
ULTRA911's Avatar
pull the code out then we can help you. your prob could lie within the CEL.
Old Mar 23, 2003 | 11:12 AM
gsrvx's Avatar
New User
yes, grab the cel code first
Old Mar 23, 2003 | 11:35 AM
markD.'s Avatar
OMG it'Z McFLY!
Default Re: check engine light... (RK)
where can i get this?
Old Mar 23, 2003 | 11:42 AM
gsxr's Avatar
for the process:
http://www.bseries.net/html/garage/engcode.php
for the codes:
http://www.team-integra.net
Old Mar 23, 2003 | 11:50 AM
markD.'s Avatar
OMG it'Z McFLY!
Default Re: check engine light... (gsxr)
in that process it says "green rubber boot"..where is this located?
[Modified by MaRkDmB7676, 9:10 PM 3/23/2003]
Old Mar 23, 2003 | 12:17 PM
markD.'s Avatar
OMG it'Z McFLY!
ttt..need help please
Old Mar 23, 2003 | 12:58 PM
markD.'s Avatar
OMG it'Z McFLY!
ok i got the cel code..it is 72 according to the bseries.net website (long flashes count as 10s and shorts count as ones)
Old Mar 23, 2003 | 01:27 PM
intekragsr's Avatar
72 is a misfire in cylinder #2.
Misfire detection is accomplished by monitoring the crankshaft speed with the crankshaft speed fluctuation sensor which is attached to the crankshaft.
check :
-fuel injector clogging, fuel leakage, air leakage
-fuel injector circuit open or shorted
-spark plug carbon deposits, fouling, malfunction
-ignition wires open or leaking
-distributor malfunction
-compression low
-valve clearance out of spec.
good luck
Old Mar 23, 2003 | 01:37 PM
markD.'s Avatar
OMG it'Z McFLY!
Default Re: check engine light... (intekragsr)
damn...thanks for the extended warrenty
is it harmfull to drive with this condition?
[Modified by MaRkDmB7676, 10:46 PM 3/23/2003]
Old Mar 23, 2003 | 01:40 PM
neo1z's Avatar
With the idle issues and everything you could have a bent valve, or simply you might need a valve adjustment.
When did this start happening - was it gradual, or just immediately one day it happened?
Do you remember ever overrevving? That could be a tell-tale sign of valve issues...
Old Mar 23, 2003 | 01:47 PM
markD.'s Avatar
OMG it'Z McFLY!
Default Re: check engine light... (neo1z)
it just happened today when i was driving..started it up, was driving fine, then just started to boug-down and not ride right. no dont remeber over-revving...always shift before red-lining.
HondaAllDay
Apr 6, 2009 09:56 AM
93blulude
Jul 11, 2008 02:41 PM
Spoolin'VW
15
Nov 19, 2005 03:27 PM
SpoonTypeR95
Aug 30, 2005 03:56 PM
TypeR714
Oct 28, 2002 07:00 PM
