question for you chrome guys
Im getting ready to tune my lsvtec Turbo crx and I have a 3 bar map off a powerstroke not a GM. How is that intruduced into the software do I still tell the software that it is a GM? Will the map sensor work? How did I use this?
it's Crome. (the H is on the car's badge not in the programme)
when you add boost tools, select custom and set the min/max limits for the sensor.
If the key on engine off voltage and min/max range is the same as the GM 3bar listed when you install boost tools (in the pull down) then use it... if it's not the same enter it under custom.
Modified by Relic1 at 1:37 PM 9/18/2008
austrian type-R
Sep 1, 2001 05:16 PM
