Problem Chipping a JDM P30 ECU. Help!
Old Apr 12, 2008 | 11:04 AM
12sec14's Avatar
Default Problem Chipping a JDM P30 ECU. Help!
Right I just got a JDM P30 chipping kit.
I bridge J1, Solder the Three little things in (C49, C50, C92)
Then I Put in the Zif socket. Tested the ECU (yup forgot to solder the 74HC373 chip in) and got a solid CEL light on the Speedo.
So.. I soldered in the 74HC373 chip and tried it again. SOLID check light again!
Left over I have one resistor and am not sure where it goes. I am following this guide..
<U>http://web.archive.org/web/20051224083544/www.pgmfi.org/twiki/bin/view/Library/ChippingJDMP30</U>
Because I kept getting a CEL light I removed J1, C49, C50 and C92. Left in the 74HC373 chip as it would have been a PITA to remove. Also pulled the Chip that I burnt!
Once removed, the CEL light is still on. Car is in limp mode!
Any Idea why I kept getting the CEL light when I connected the bits up?
Please help, Its not my ECU!!
Old Apr 12, 2008 | 09:57 PM
mtber's Avatar
Default Re: Problem Chipping a JDM P30 ECU. Help! (12sec14)
1. Did the ecu previously have a 28 pin eprom chip installed from the factory ?
2. If not, when you removed j1, you still have a solid cel (limp mode) ?
If so, your ecu is damaged.
Old Apr 13, 2008 | 01:38 AM
12sec14's Avatar
Default Re: Problem Chipping a JDM P30 ECU. Help! (mtber)
No EEPROM installed when I started. Now I remove J1 and the CEL light is still there!
I still need to remove the 74HC373 chip. Would this throw a code?
Old Apr 13, 2008 | 08:22 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12sec14 &raquo;</TD></TR><TR><TD CLASS="quote">No EEPROM installed when I started. Now I remove J1 and the CEL light is still there!
I still need to remove the 74HC373 chip. Would this throw a code?</TD></TR></TABLE>
Sounds like you damaged your ecu some how.
jpar195
Apr 7, 2008 12:01 PM
madtownhonda
Mar 29, 2004 08:09 AM
phiberoptik
Dec 6, 2003 05:06 PM
