O2 SENSER DELETE HOW TOO
Why do you want to delete your O2 sensor? I've never seen an O2 sensor delete.....
You will need a tunable ECU or a standalone EMS if you want to effectively run your car without an O2 sensor.
So are you only looking to delete the secondary O2?
I am not aware of any off the shelf secondary O2 delete kits. There are some people who have used a couple spark plug non-foulers to keep the CEL light from coming on with a cat deleted system. However, this still requires the secondary O2, w/non-foulers, to be installed into a bung on the test pipe or somewhere else downstream.
