zdyne help ?
Old Oct 14, 2002 | 10:08 AM
linx's Avatar
Default zdyne help ?
I am using a 200 mmx and i am getting check sum errors any sugestions whats causing this ?
Old Oct 14, 2002 | 10:16 AM
SiR Kid's Avatar
New User
Default Re: zdyne help ? (linx)
Check sum errors are usually because the Program cannot "talk" to the ecu. Are you using a PHONE cable or the data cable that came with the Z-Dyne? That was one issue that I've heard about with some users.
Also, this is a dummy error, make sure the key is "on" when you try to upload changes.
If these aren't the problem, please explain when you are getting Check Sum errors. Can you even load the program? I've only got a 250 MMX machine, and I run the program with flying colors.
Old Oct 14, 2002 | 12:35 PM
shotty's Avatar
Default Re: zdyne help ? (SiR Kid)
Like he said. Make sure your key is "on" The ecu needs to be plugged in and w/ the key on.
Old Oct 14, 2002 | 02:59 PM
linx's Avatar
the key is in the on position and i am using the black cable provided by zdyne. I am using my desk top just so i can load a base tune until I get my lap top. Is there any port settings I should check ?
dart2.2
Engine Management and Tuning
12
Sep 20, 2008 07:45 AM
DelsolioGSR1996
Sep 5, 2006 08:50 AM
bulldog_RS20
Apr 9, 2003 12:45 AM
linx
Oct 15, 2002 10:04 AM
