Neptune Moates Demon
I'm waiting a couple of months to let everything shake out a little bit.
But this is the next major upgrade for me.
Neptune+Moates = win^100000......
The final units are in and we tested them in the field before starting to ship them, just in case. Keep an eye out, it looks like only good things will come.
An install and demo video thanks to John Kerr of J-K-Tuning.
http://www.youtube.com/watch?v=rtaEsxAo-ug
saw the vid last night!! good stuff, seems your one of the easiest to reach for support etc and deserve all the praise you get with neptune
Just received mine today
Seems the Crome beta connects to it. Never used Neptune nor do I have a license for it, but since it seems Neptune is the way to go at the moment, this is my first experience with tuning anything myself, looks like there is some fun to be had here O.o.
Tried searching for this.
But does the demon support dual / or more switchable configurations.
Im considering going E85 on my car, but i also want to have my gas map avail for those times that i cant run e85.
If it has it, could you install some easy switched to swap between the configs?
Or you can switch them based on several sensors like TPS, Map, etc. See the "Switch Maps" section of the parameters under Extras. You can also have it switch when an output is activated.
On the inputs that are grounded (Labeled in the software) you can use a 2 prong switch. One to the ECU pin you're using, one to ground. Not much of a diagram needed.
i've been beta testing this for years before it was released..
I must say.. its quite the invention..
pretty much compatable with any software out there now.
I have been beta testing demons for over 2 years.
This new demon you guys are just starting to sell or have gotten your hands on, i've had for over a year.
My last setup was tuned on crome pro via this rtpboard.
I work closely with craig's worker, i'm their test mule everytime something new comes out.
The final version of the Demon has everything on one COM port and Crome's support of that is not working properly. i.e. it doesn't work with Crome Pro currently.
i know.. i beta tested..been using it
i have a map right now, on crome, matter fact, i can show you if you want.. via ss's.. right now, it works on crome fine.
dunno which one ur using..
My works fine with everything..
my last motor was ran on crome pro via this board.
Go read about it on the pgmfi forum. The latest release is the only one said to support the Demon properly (That means datalogging and uploading on one COM port) and people can't get it to work properly. Maybe you can help them all get it working instead of sitting here arguing over nothing.
oh, i see what your saying
The crome pro i used isn't the newest one, its the 1.5 version or w/e.. i haven't used cromepro since my last tuning on my car..
i only use ectune now..
