Peakboost kit need b16 start up map!!!!
Old Oct 26, 2008 | 10:38 AM
ONEQWKSI's Avatar
Default Peakboost kit need b16 start up map!!!!
Hey wats up guys....I know that people prob. post this up every few days, but i need a base map so i can get to the tuner and be able to move my car. I have a s300 and i see that they have a base map for a greddy kit. Will that work for a base map , or does anyone have a map that is close to what i have in my b16a2, with skunk2 stg 1 cams, skunk 2 intake manafold, 60-1, 63.trim turbo, 44mm wast gate, 750 rc injectores, 255 walb. pump, with stock internals. I need a map with low boost....approx 6-8 lbs.. Thanks....
Old Oct 26, 2008 | 02:18 PM
RC000E's Avatar
Default Re: Peakboost kit need b16 start up map!!!! (ONEQWKSI)
You don't need a boost capable map to get to the tuner. Use a simple map that's rescaled for your injectors, then drive part throttle/out of boost to your tuner.
Old Oct 26, 2008 | 04:59 PM
ABK's Avatar
ABK
Default Re: Peakboost kit need b16 start up map!!!! (RC000E)
Just start a new map. Input your injectors and all that stuff. Pull some fuel out/in until it starts. Just follow the datalogger. If you don't have a wideband I suggest you just tow it.
Old Oct 26, 2008 | 07:16 PM
ONEQWKSI's Avatar
Default Re: Peakboost kit need b16 start up map!!!! (ABK)
Thanks for the info....So i can use the hondata s300 greddy base map in order to get me to the tuner and be able to drive it....
Old Oct 27, 2008 | 07:21 AM
mtber's Avatar
Contact the dealer you bought the s300 system from, they should be able to help you out.
We provide all our customers with a calibration for their setup upon purchasing a hondata system from us
Old Oct 27, 2008 | 07:34 AM
ONEQWKSI's Avatar
Default Re: Peakboost kit need b16 start up map!!!! (mtber)
yea i already tried, but the guy who sold me my hondata does not know his *** from his elbo!!!(lol), so thats why im trying to get a little info from you guys...I understand that i'll be able to start the car up with the base map (Greddy Map) that the hondata has in the file part of the s300, but will it be safe to drive without hitting boost to my tuner....my be i just have to contact the tuner and see if he has a base map for me!!!! Another note whats the differnce in haveing a stock map sensor vs a 4 bar, if your keeping boost uder 12psi...
Old Oct 27, 2008 | 09:17 AM
RC000E's Avatar
Stock sensors max out at 11.3 psi. Management needs to know which your using for the car to run properly.
sewokozak
Engine Management and Tuning
Aug 9, 2018 02:08 PM
ef9itb
Jun 26, 2010 06:25 AM
b20turbocivic
14
Dec 28, 2009 11:31 AM
Bbasso
Jan 25, 2005 06:09 PM
