Mpg build
Old Dec 23, 2012 | 07:24 AM
  #26
spAdam's Avatar
Loved
Community Favorite
Default Re: Mpg build
Originally Posted by Rusty94cx
I want lean burn. Why don't you have it on that setup? I don't want to buy a burner to burn like 2 chips. Right now with a shot 02 I get 42. But with the cel on I know there is no lean burn. I don't want to spend 25$ for a 5$ chip plus shipping. I'm not running some motor that never came in a civic. I'd that setup wouldnt let me get lean burn then it wouldn't be worth it. I'ld be really sad then. Hmm I saw the basemaps that where I got the idea. Why no lean burn...
You can't lean burn the way the VX did without the VX ecu and a wideband. You feasibly could use that basemap along with a wideband and your chioice of tuning software to come up with your version of the routine, but it's not going to work the same as the original.
Old Dec 23, 2012 | 08:01 AM
  #27
raverx3m's Avatar
p07 ecu has a built in wideband controller and it also controls egr valve
just buy a p07 ecu and you will get leanburn
Old Dec 23, 2012 | 01:03 PM
  #28
Rusty94cx's Avatar
I would be happy with a basemap p07 with 02 delete that still allows lean burn.
Old Dec 23, 2012 | 01:12 PM
  #29
GhostAccord's Avatar
In that case why not just buy a P07 and wire the engine harness accordingly???? You need everything else that goes with it though.
It would be much better than trying to run a P07 basemap on a non wideband non P07 chipped ECU. :thumbsup:
Old Dec 23, 2012 | 03:30 PM
  #30
Rusty94cx's Avatar
The car is all stock I have the federal p07 ecu. I just font want to spend 200$ dollars every couple of years for an 02. I want to know if I can have a chipped p28 running a p07 basemap with 02 delete and still achieve lean burn.
Old Dec 23, 2012 | 04:41 PM
  #31
spAdam's Avatar
Loved
Community Favorite
The lean burn function is a closed loop operation afaik. It will not work without some sort of feedback to the ecu. If it wasn't there would be no reason for the engine to have an LAF sensor.
Old Dec 23, 2012 | 04:58 PM
  #32
Rusty94cx's Avatar
But why can't it be done? The last 02 only lasted a little over a year and the dealer wants 550$ just for the part.
Old Dec 23, 2012 | 05:11 PM
  #33
raverx3m's Avatar
wideband O2 sensor regulates the afr.
california banned leanburn so if you can find cali spec p07 then use it
in very simple words NO WIDEBAND=NO LEAN BURN no matter how many times you axe us.
the p07 map from xenocron and pgmfi worked just fine for mine it actually was very very close to 14.7 when i hooked up my innovative wideband.
do you understand what leanburn is? just asking
the closest you will getwithout LAF is to get it dyno tuned
and its not 200 dollars every 2 years. they last alot longer than that if the rest of your engine is well maintained.
NTK 24300 is the part number for an OEM spec LAF sensor
if you try to do it without wideband you will blow it up
Old Dec 23, 2012 | 05:12 PM
  #34
Rusty94cx's Avatar
Why couldn't it be done with just a map and load input? Base perameters. Someone has done it they just want way to much.$$$ I'm on a budget.
Old Dec 23, 2012 | 06:37 PM
  #35
Rusty94cx's Avatar
Yes leanburn is a overly lean condition that is almost to the point of piston melting. Extreme gas sipping. The car had a brand new 02 1 year ago before I bought it. It has and is failed I don't know if possibly that is because the cat has been hollowed out not having the heat to help keep it clean and burnt off. The car uses no coolant no oil and vac is rock steady and strong. I get 42-43 mpg as is so the motor is a+. I have herd that the denso sensor is better than the ntk. And yes I know it is supposed to last more than 2 years. Like I said there is a guy selling ecus but they are 350$ for that ild go with Neptune or something along that line. I drive alot of steady 45 50 mph driving perfect for mpgs. So the guy selling the ecus are full of ....
Old Dec 23, 2012 | 09:54 PM
  #36
raverx3m's Avatar
Ok then can you answer why honda went through all the trouble to put a wideband controller and wideband o2 sensor on vx if theres no need for them?
Old Dec 24, 2012 | 03:43 PM
  #37
Rusty94cx's Avatar
There are emissions laws and also you ate being risky. You have to have double redundancy. Not everyone knows to get off it when you hear a ping or a knock. Every manufacture has a very safe and conservative tune. Every car from 79-80 in north America has an 02 how many of you guys are running an 02 delete code with no problems. Im not saying it can be done I just want to know if it's been tried and if there was success or failure. Or if it's uncharted territory.
1LowSol
Feb 8, 2009 10:34 PM
vargas
Mar 2, 2008 10:46 AM
drewb16a
Jul 17, 2007 10:07 PM
hatchback19
Jul 22, 2003 09:50 PM
