Kpro ECU wont power up
Old 11-13-2012, 04:49 AM
3k1n's Avatar
Default Kpro ECU wont power up
So I have a 99 Hatch with a k24 kpro'ed. The car has been running fine for a couple of months. Last night took the car for a spin, parked it, popped on the fuel cut kill switch. When I came back I turned off the fuel cut and noticed the fuel pump was not priming when I turned the key one click before turning the car on, and then noticed the CEL was not lighting up, which meant the ECU was not getting any power. First thing I did was check all the Engine grounds and they were fine. Checked the 3 relevant fuses, and they were fine. Checked the wiring on the ECU to see if any of the wires came off the pins and they appear to be fine.
Could the kill switch have possibly short circuited something? Possibly the ECU? Anyone have any suggestions as to what else I should be looking into?
Old 11-13-2012, 05:36 AM
xenocron's Avatar
Default Re: Kpro ECU wont power up
Your switch is probably bad, or maybe you popped a fuse.
Old 11-13-2012, 05:42 AM
3k1n's Avatar
Yes I checked what I believe are the 3 fuses related to the ECU and the Fuel Pump. At first I thought It was a bad switch, so I removed the kill switch and just wired the fuel pump without it. I believe its an issue with the ECU as the CEL light does not pop up, and the green light on the ECU doesnt light so I'm assuming no power is going to the ECU.
Old 11-13-2012, 02:28 PM
xenocron's Avatar
Correct, it's not the ecu...it's your power supply to the ecu
Old 11-14-2012, 05:27 AM
3k1n's Avatar
Anyone got any suggestions?
Old 11-14-2012, 10:23 AM
Spunkster's Avatar
Try the ECU in a known working vehicle. If it works you know you have an issue to resolve in your own vehicle.
pimpdd101
03-05-2009 07:46 AM
no1knows908
04-21-2008 10:35 PM
jadugartir
17
12-18-2006 05:38 AM
efboy
Audio / Security / Video
09-24-2004 02:06 PM
Mugen Hamster
28
03-01-2004 05:28 PM
Quick Reply: Kpro ECU wont power up
