Help with reading check engine light code
CEL CODES 92-95 and how to read them
HA motorsports CEL code list
If the car is something obd1 converted and doesn't have the two wire connector to jump the check engine light jumper you can ground ecu pin d4 direct to chassis to make it flash. thatd the far right ecu plug looking at the ecu plug side first. Bottom row second to the left.
SmogKing
Aug 3, 2006 12:48 PM
Egezzy
May 6, 2006 05:53 AM
