Help please! B16 build
Old Jul 25, 2025 | 02:00 PM
Ej0310's Avatar
Default Help please! B16 build
I’m looking at buying a 99 ek with a fresh rebuild on a b16 with a gsr block. When it’s started it sounds like it runs rough but the seller assures me it’s because it doesn’t have a fast idle control valve due to the jdm intake. When it’s up to temp it runs like a dream. Should I be concerned, or is it a good purchase?
the full build is Fresh rebuild on motor poormans type r
gsr block ls crank and rods
usdm type r pistons
acl new main & rod bearings
usdm nippon oversized pistons 81.5mm
arp main studs & arp head studs
honda oem parts- oil pump, water pump, head gasket, timing belt, oil cooler,
stock b16 head
brand new competition stage 2 clutch with their lightweight flywheel
no grinds or pop outs oem honda transmission fluid
on a chipped ecu with no rev limter
yonaka catback exhaust with oem header
ice cold ac also has heat
new alternator
engine swap at 125090
new rear timken bearings
new starter
Old Jul 25, 2025 | 07:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Help please! B16 build
You didn't mention a price... so there is no way to tell you whether or not it is a good deal. As for the engine build... buyer beware.
Old Jul 26, 2025 | 05:42 AM
Ej0310's Avatar
8500
Old Jul 26, 2025 | 07:08 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Since the engine is suspect... the rest of the car would have to be PERFECT for that kind of $$$.
Old Jul 26, 2025 | 07:48 PM
Ej0310's Avatar
the rest of it is perfect, no rust, lsd trans, full interior, paints great, nice wheels, needs tired but aside from that it’s mint.
jdm510
24
Jan 1, 2011 08:17 AM
1990hondacrx
Apr 1, 2010 02:54 AM
XkjeldorX
Appearance Build Threads
31
Jun 1, 2008 08:16 PM
BrianSi91
Northeast (Sales)
May 26, 2006 02:53 PM
drewbie*
Mar 21, 2004 09:19 PM
