chipped p61 ecu will not work!!!
Old Mar 17, 2007 | 10:37 AM
Da1spaz247's Avatar
Default chipped p61 ecu will not work!!!
Hello. I chipped a p61 (not at all my first chipping job) and with the jumper on, it throws solid CEL immediately. Assuming I somehow messed up the solder or something,, I decided to send it in to xenocron to have him fix it. He said upon arrival it didnt work with his or my chip, so he cleaned up the solder and then he said it worked with his chip, but not with mine.
So I burned a new chip with a bin that he (chris harris) sent me, still solid CEL.
-Then I tried my friends chip (which is a known working chip) in my ecu, solid CEL.
-I tried my friends chip in his ecu in my car, worked fine.
-I tried my chip in his ECU, worked fine.
-Also, when the jumper is removed, my ecu works fine with no codes.
Is there something different about the p61 that I need to accomodate when I program the bin? I tried disabling checksum also. and im using crome. Any ideas what to try? THanks.
Old Mar 17, 2007 | 07:42 PM
Da1spaz247's Avatar
Default Re: chipped p61 ecu will not work!!! (Da1spaz247)
anyone have a bin from a working chipped p61?
Old Mar 18, 2007 | 12:32 PM
mmuller's Avatar
Mad Scientist
i can send you a program for you to burn
Old Mar 18, 2007 | 12:38 PM
Da1spaz247's Avatar
Default Re: chipped p61 ecu will not work!!! (mmuller)
please!
Old Mar 18, 2007 | 01:00 PM
mmuller's Avatar
Mad Scientist
ok, well pm me your email
and let me know what sensor you have or dont have
Old Mar 19, 2007 | 05:39 AM
eg6ajk's Avatar
p61 is no different then USDM P30 and P28 (minus the knock sensor board). Just as a side note. P61 came originally from factory with EPROM.
if the program runs in p28 then it surely will run in p61 !
Old Mar 19, 2007 | 07:32 AM
Da1spaz247's Avatar
Default Re: chipped p61 ecu will not work!!! (eg6ajk)
ok, so I have determined that it can't be a programming problem. I hooked up my ostrich and tried all the base roms that come with crome, then I tried disabling each option, and I did remove checksum on each one. After getting NOWHERE with anyone of those combination, I determined there must be a hardware problem still. I'm sending it back to chris harris at xenocron for him to see what happened. He says something must have gotten messed up in shipping, because it worked when he sent it out.
B20Luder
Engine Management and Tuning
Aug 1, 2010 04:14 PM
HamiltonRex
Oct 23, 2005 07:11 PM
siregcivic
Aug 20, 2005 02:39 AM
Toadfart
Apr 14, 2004 12:03 AM
Slow Egg
Mar 20, 2003 09:07 PM
