h22 turbo
Old Sep 7, 2009 | 06:48 AM
Rob C's Avatar
Default h22 turbo
i am looking at fitting turbo kit to my h22a vtec but wanted to run standard internals... how much psi could i run to be safe?
also is it possible to run standard ecu or would i need a different ecu if running boost?
Old Sep 7, 2009 | 10:44 AM
Shartek's Avatar
Default Re: h22 turbo
Hondata s100 or s300 for your fuel management
and no more than 8psi with a good tune.... or you will crack a sleeve.....
Old Sep 7, 2009 | 11:36 AM
Rob C's Avatar
a sleeve? you mean piston?
Old Sep 7, 2009 | 06:39 PM
Mr.Milton's Avatar
it depends on the tune.. ive seen 14psi on a stock block
Old Sep 7, 2009 | 06:50 PM
TheShodan's Avatar
Moderator
There are tons of this on the H22 Turbocharged engine via searching the archives. You'll be surprised in what you find.
93 Eg Couper
May 20, 2009 11:51 PM
donm3ga
Feb 13, 2007 08:17 AM
lude98SH
Dec 6, 2006 11:39 AM
94_accordVTEC
Nov 27, 2005 08:25 PM
gdrum
Apr 26, 2004 10:45 PM
