Freelog AFR issues
So everything seems to be coming into freelog no problem. all my sensor information is there. Im running an Open loop chip. im running the analog output of my LM-1 into wire D14 (stock O2 signal) and freelog is display the AFR. the problem is i can't seem to get it to record any of the AFR on the rpm/load table. The little box moves around but nothing seems to record.
Its weird because if i go to the "target AFR" tab in freelog it records all the AFR information there. How do i get it to fill up the main rpm/load table with the AFR at each given cell?
hitting "Log" at the top seems to do nothing.
Also, im running an Ostrich 2.0 with CROME with real time updates enabled. do i need to enable anything specific in CROME for this to work? i dont see why as freelog seems to be a stand alone program.
thanks in advance
thanks in advance
anyone else? was hoping to do a lot of datalogging this weekend but if its not recording AFR im just wasting my time, and fuel.
Does RTP + Datalogging (plugin) need to be enabled in CROME for the emulator to work in conjunction with the datalogging or what?
It means your parameters are out of range, it won't record until it's in range.
i.e. if your minimum ECT value is 180, it won't display data until the engine is hotter than 180*
This is all in Tools > Settings > Wideband
Set the values as loose as possible until you start getting data, there's no reason it won't work if your cell tracing is accurate.
^x2
I ran into this same issue a few years back when I was having registration issues with Crome Pro and had to run Freelog for a weekend at the track.
I set everything to as low/loose as possible. IIRC I even put 0 in for gears as well to log idle AFRs.
Max500
Engine Management and Tuning
12
Oct 16, 2011 09:12 AM
