Assistance needed: D16Z6 ECU / Wiring Harness Diagram/ Pinout for classic Mini Cooper
hi all I'm new here. iv just fitted a d16z6 into my classic mini i have a p28 ecu and i was wondering if anyone has a pin out for the ecu what each wire does and pin out for the 5 plugs in the engine compartment. any help is muchly appreciated
Re: Assistance needed: D16Z6 ECU / Wiring Harness Diagram/ Pinout for classic Mini Co
If you want to build essentially a stand alone engine harness the easiest way I've found is by running a 96-00 civic ex harness with a obd1 jumper harness. Basically it gets rid of the shock tower plugs besides one which is mostly ecu power, ground and the fat wire for the starter solenoid. I wired up my crx all motor drag car this way and it was very easy. I'll be doing the same harness setup on my insight when I single cam swap it. The ecu plugins go straight into the cabin and the green plug is for the cluster if I remember right.
veekster87
08-21-2010 12:16 PM
