Willem Dual burner problem. AT29c256. Crome/Uber HELP!
My Willem burner is acting retarded. ive burned 100's of AT29c256 and 27c256 chips on it.
I just got a new computer and uploaded the willem software now i cant burn a damn thing.
If i click read chip. and then click write to chip. it will write a program to the chip.
But if i try to burn a Crome Bin then it gives me the Error: write sector 0
How do i fix this? i am using the jumper to pin 3 to pin 31 i am using the 97g
when i click to verify the chip i get this : " Error at 0x000000 Chip = 0x00 Buffer = 0xFF
When i click blank test i get this " Device is not empty $0000000"
The chip is installed correctly
the chip is not Id'd when i click the ID tag i get this
Manufacture 0xE2 (''''')
Device code 0x00
in the buffer log all it reads is FF in every cell.
i have no clue whats going on with his. everything worked fine til i got my new computer cause the old one was a POS.
Ive tried all the willems programs and all kinds of different settings. it can read its self and write the program that it read. but it will not burn uber/crome ect Bin files.
Device code 0x00
Re: (JDMlyfestyle)
Sorry i dont know what is wrong with yours but from my expierence Willems burners are VERY tempormental. Mine has left me stranded a few times, it's a good cheap burner but you could use this as an excuse to buy a new USB burner.
Re: (ScottEK)
may sure the jumper is touching the chip's pin in #3. also if you put the jumper 2-31 your burner should id the chip correctly. i'm sure you have tryed this. double check all jumpers too. Xenocron has some good links on his site http://www.xenocron.com/
http://www.homemadeturbo.com/f...35497
good luck
good luck
thanks for the info. ive already seen those sites tho. didnt offer much help for me
Ok i tried different jumpers. still getting a write error sector 0
Unistalled and reinstalled program and its still messin up. still write Error sector 0
Tried burning some blank 27c256 chips and still Write Error Sector 0
i tried different strands of wire, paper clip, solder, and still no worky.
rexload
Engine Management and Tuning
12-22-2008 07:58 PM
JDMlyfestyle
07-17-2005 11:11 PM
89Si
11-07-2003 09:48 AM
