Need help with Engine Code 20! 911
Old Feb 10, 2004 | 12:34 AM
Turboracer01's Avatar
Default Need help with Engine Code 20! 911
Ok So I have never gotten this code before so I'm not quite sure how to go about Troubleshooting it. I could use anyone and everyones help any ideas suggestions anything would be GREATLY!!! Appreciated I have a race this friday so I need help like yesterday. Here is a break down of the code:
I do have the GM 3 bar map sensor, And a resistor box wired in for the 720 cc In jectors. But everything fires up just fine. And I cut the entire wire harness going to the headlights on the left side. But just on one side. So any ideas guys.
CODE 20:
Electrical Load Detector defective circut or unplugged/ defective sensor.
Old Feb 10, 2004 | 12:47 AM
jdmDXrex's Avatar
Default Re: Need help with Engine Code 20! 911 (Turboracer01)
whats your car/setup....
my obd 1 converted crx has that code because i dont have ELD..... doesnt bother performance at all
Old Feb 10, 2004 | 04:56 PM
Default Re: Need help with Engine Code 20! 911 (jdmDXrex)
2001 Turboed GSr converted from obd II to OBD I.
Old Feb 10, 2004 | 05:55 PM
hondatim's Avatar
I assume you're running a stand alone engine management system with 3 bar MAP sensor. Is it Hondata, if so, you should be able to disable this input.
Let us know...
d_boi_swag
Jul 5, 2009 12:14 PM
saver
Mar 28, 2006 10:19 PM
blacksi-t
Sep 21, 2003 01:21 AM
Flexmyrex
Aug 16, 2002 08:46 PM
