check engine light...
Old Mar 19, 2003 | 07:16 PM
integraL's Avatar
Default check engine light...
my uncle redlined my car. he brought it back and turned the engine off. when i started the car, the check engine light came on and the rpms moved up and down. the engine isnt as steady as it was before..any suggestions?
[Modified by izkevin, 4:17 AM 3/20/2003]
Old Mar 19, 2003 | 07:24 PM
boosted_dc2's Avatar
Default Re: check engine light... (izkevin)
what year is your car??? obd1??? what code is it throwing
Old Mar 19, 2003 | 07:30 PM
integraL's Avatar
Default Re: check engine light... (hooked_up_gsr)
its a 99 gsr....what codes are you talkin about?
B00ST2nR's Avatar
jump the code and see what it throws out. Then we can tell what the problem is or where it is comming from at least. Do you know how to jump the CEL Code?
Old Mar 19, 2003 | 07:33 PM
integraL's Avatar
Default Re: check engine light... (Skunk2nR)
no i don't, will you explain? thanks
Old Mar 19, 2003 | 07:38 PM
neo1z's Avatar
<sighs> sounds like your uncle overrevved your car...
To jump the CEL, go under the passenger panel, at the very right, youll see a little blue plug. Pull it down, and jump it (put a paper clip in it). Then turn on the power, the CEL will blink. Long blinks = 10, quick blinks = 1.
So if its long long fast fast = 22. fast fast fast = 3. etc.
anyone have a pic of that stuff -- i have a feeling saying this isnt going to be good enough
Old Mar 19, 2003 | 07:39 PM
B00ST2nR's Avatar
http://www.c-speedracing.com/faq/06.php
Old Mar 19, 2003 | 08:19 PM
integraL's Avatar
i think i need new spark plugs...its cylinder #4 that is misfiring
Old Mar 19, 2003 | 08:22 PM
B00ST2nR's Avatar
Check your compression ratio. Maybe its a bent valve?
Old Mar 19, 2003 | 08:39 PM
integraL's Avatar
how do i check that? i just got my car 2 weeks ago...=\
Old Mar 19, 2003 | 09:30 PM
B00ST2nR's Avatar
If your Uncle mis-shifted and went over the Redline, then there is a good chance he bent one or a couple of valves...
But you can tell when you have bent valves. Your idle is really shitty and the car will choke and NOT want to run. There's also a ticking noise that will come from the motor.
If all of this applies, then get a compression test done and see if you're losing any compression.
93blulude
Jul 11, 2008 02:41 PM
Bambinoh
Apr 25, 2007 04:35 AM
UpstateCivic
Jun 7, 2003 12:27 PM
lilxvtecxpwr
Oct 13, 2002 11:04 PM
