Bank 1 system too lean???
Old Feb 10, 2016 | 07:41 PM
Anakarp's Avatar
Default Bank 1 system too lean???
Hi guys okay so here I am cruising along in my little 97 Del sol....
And BAM! 3rd gear 2500 rpm the car bogs and with more pressure on the gas pedal. So I press harder and shift to 4th and bogging stops.
Happens every now and then at 2500-3000 rpm in 2nd and 3rd.
+add seafoam and run it on interstate.
Two days later, again cruising along, BAM! check engine light. Bank 1 system too lean.
Car bogs more than usual now.
Idles fine.
So now, my question(s) is,
I have no cat. And the car is obviously obdII. Would that light up this glowy orange thing on my dash? (BTW, this Honda feels like a VW now. )
Also, it's a d series y7 with a y8 intake.
I DONT have a filter on my intake.
Could that cause it to throw a code too?
Old Feb 11, 2016 | 11:57 AM
motoxxxman's Avatar
Default Re: Bank 1 system too lean???
get a fuel pressure test done. your pump may be dying. sounds like a classic example of fuel pressure being too low
Joka74
27
Aug 25, 2014 05:56 AM
Itzmy91Teg
Oct 10, 2008 07:16 PM
gsr converters
Sep 13, 2006 10:08 PM
95'turbotegra
Jul 17, 2005 05:50 PM
SolidSpruce
May 18, 2002 02:46 AM
