AEM v2 30-6051 , Mag to Hall
Old 03-17-2015, 12:37 PM
flatblack-h22's Avatar
Default AEM v2 30-6051 , Mag to Hall
hello, i recently purchased this unit (6051) to use on my swap full 6mt swap. the ems unit itself was made to work with an auto harness. the current configuration for crank and cam gear is set to mag. I've read that it can be swapped to hall with the move some jumper inside the board and change the tooth count in the software. Is there some truth to this? There are some company that make a jumper to connect the ems side to my engine harness.
Old 03-18-2015, 06:10 AM
Default Re: AEM v2 30-6051 , Mag to Hall
Is this supported
Old 03-20-2015, 03:16 PM
DraginX's Avatar
Yes there are jumpers inside the ems to change from mag to hall, and you can also change the tooth count in the program. If you are unsure how to do both call the AEM tech line on your box. They are very helpful and usually very easy to get a hold of. I've called a few times and their help tech support has been great for me.
mhax
Engine Management and Tuning
05-24-2013 04:27 AM
1990hondaHF
Acura TL, RL & ZDX
08-07-2010 02:34 PM
ebydrc
05-17-2006 06:35 AM
DYNOmike
Acura NSX
09-23-2005 01:41 PM
da_rimrocka
03-12-2005 04:32 PM
Quick Reply: AEM v2 30-6051 , Mag to Hall
