YCP Pistons What Rods?
Old Feb 18, 2019 | 08:50 AM
D21X's Avatar
Default YCP Pistons What Rods?
Hey guys i have YCP 84.5mm floating pistons for my b20vtec. My problem is the piston clearance for the rod is small. Not sure what aftermarket rod will fit.
Looking at specs looks like skunk2 might fit piston end width is .827. Eagle is .935. Manley is .849. YCP clearnce is just a tad larger than skunk2. YCP rod clearance is .850.
Whats everyones experience?
Old Feb 18, 2019 | 09:22 AM
D21X's Avatar
Default Re: YCP Pistons What Rods?
I am afraid of this happening:
Old Feb 21, 2019 | 05:14 PM
flesh199's Avatar
Shave the small end of the rod about 0.040 inch per side.Its the same practice with ctr piston on b16a rod
Old Feb 21, 2019 | 09:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I just did this on my new "K" build. Time consuming, but it works like a champ. Cutting the rod takes more weight off of the rotating assembly than removing material from the aluminum pin bosses... I cut .030" from each side of the rods and averaged a reduced rod weight of 4.4 grams each.
If you don't want to modify the rods, you can buy aftermarket rods with a narrower pin end and you will be fine. Measure the opening between the pin bosses on the back of the piston and make sure that the rods that you choose has a NARROWER pin end width.
Old Feb 25, 2019 | 03:53 PM
D21X's Avatar
Thanks for the tip guys. I bought Skunk2 Alpha rods and they fit without having to do any machining work. Not sure why the guy in the youtube video didn't fit.
Old May 13, 2019 | 08:27 PM
BoostHatchFreak's Avatar
because ycp pistons quality control is not the best ive had the same problem in you tube video with b20 stock rods even. glad your works you want .030-.050 side to side clearance with rod centered in the piston.
D21X
Feb 18, 2019 09:43 PM
Rootie524
Jul 4, 2011 01:26 PM
jetlude
Jan 18, 2008 04:43 AM
vtecmonster001
Jan 13, 2005 08:12 AM
CRX Lee
Feb 9, 2004 08:39 AM
