Is this the right size Flex Hone for a B18B?
Old Jun 10, 2015 | 02:22 PM
diatibe24's Avatar
Default Is this the right size Flex Hone for a B18B?
I have stock bore 81mm in my LS and would like to use a Flex Hone if possible. When I do a conversion from mm to inch I get 3.188 inches. The closest I can find is this
Brush Research FLEX-HONE Cylinder Hone, GB Series, Silicon Carbide Abrasive, 3-1/4" (83 mm) Diameter, 240 Grit Size: Amazon.com: Industrial & Scientific Brush Research FLEX-HONE Cylinder Hone, GB Series, Silicon Carbide Abrasive, 3-1/4" (83 mm) Diameter, 240 Grit Size: Amazon.com: Industrial & Scientific
so will that work or do they not make the proper sized hone?
Old Jun 10, 2015 | 05:49 PM
PrecisionPerformanceParts's Avatar
Default Re: Is this the right size Flex Hone for a B18B?
Get the 83mm as you want it oversize for the bore. 83mm can do bore size as small as 76.
Old Jun 10, 2015 | 06:17 PM
diatibe24's Avatar
Okay, good so yes this will work for my application
Old Jun 10, 2015 | 07:06 PM
blackeg's Avatar
if u are looking to just deglaze the cyl walls id look for a 400-600 grit 240 is pretty coarse for a final home imo. flex hones are actually pretty easy to use. u should have a good dial bore gauge too so u can measure out of round and cyl bore so u know how much u took off and what ur ptw tolerance will be.
Old Jun 11, 2015 | 09:54 AM
diatibe24's Avatar
I am using Hastings piston rings and they say to properly seat their rings to use a 240 grit with a 45 degree cross hatch. I know in in the manual it says 400 grit but I am not using stock OEM rings. There is some light scratching in one cylinder, just enough to feel but not even enough to catch a nail on. I figure the coarser grit should take care of it. I am not going to hone it 20 over as I could risk cracking the cylinder.
Old Mar 25, 2024 | 02:33 PM
DA9Dark's Avatar
Hey man we are finishing up a b18a1 build, deciding on rings, we are going budget build so OEM is out (i know how much we love OEM on here but $200 on rings is not budget lol) saw you used hasting rings and the 240grit is also much cheaper than 400 grit flex hone. So it's been a while since this post and curious how your hasting rings turned out? They are a very cheap option but never used them myself I was gonna go Mahle/Clevit and am still considering they are $100 not budget but half the price of OEM for a brand I can trust I can deal with. Then I ran into this thread, so how do oyu like those rings? How did the Hastings hold up? Would you go Hastings again? It's budget build but we have put the price tag where it counts, just wondering if its worth saving here for hastings or going Clevit?
Also side note anyone know what grit Mahle Clevit recommends for thier rings? I'll call tomorrow they are just closed as I am doing this....
Jitterbug831
Oct 5, 2012 06:43 PM
AFAccord
30
Feb 13, 2009 05:55 AM
xasiansupermanx
Dec 10, 2007 02:06 PM
Quetzolcotl
Mar 20, 2003 08:50 AM
GreenR
Jan 29, 2003 03:39 AM
