Reverse dome vs flat top pistons
Old Jul 11, 2015 | 03:17 AM
hoffdaddy's Avatar
Default Reverse dome vs flat top pistons
The usage here is kind of wide so I'll give you kind of a ballpark. Combustion chamber should be 53.8, bore 86, stroke 97, deck height 219.5, piston to deck height should be flush (its a h22/f23). I'm more worried about flame travel more than anything because it may or may not be centrifugal supercharged with an intercooler. I think a flat top will yield 10.78:1 compression which is a bit much going the forced induction route but not impossible, stock is 8.8:1 with a -14cc reverse dome and that's not very much for n/a, but I hear it makes good power. So if a flat top piston does not have better combustion then I'm going the reverse dome route, what exactly idk maybe 9.5:1ish. I know that's a lot of numbers and bull crap, I'm a technical guy and I'm in the middle of planning, so all I need you to say is flat top or dome if you have anything else to say throw it at me.
Old Jul 11, 2015 | 05:09 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: Reverse dome vs flat top pistons
You know people are at like 11.0-12.x and are pushing mad lbs of boost nowadays. 10.7 aint really much man. If you have a good tuner, you cam even go a bit higher..
Old Jul 11, 2015 | 08:04 AM
hoffdaddy's Avatar
Oh yeah I know, but I don't really want to but I don't want to do that with the only block mods being h beam rods and forged pistons and it being a street car that I will drive most days, not my only car, but closest thing to a dd. I don't want to exceed 550hp and that's just my limit in reality I don't want to go anywhere near that. If I was running a supercharger I'd probably only run a few pounds of boost, it doesn't take much anyway.
Old Jul 11, 2015 | 09:00 AM
PyroProblem's Avatar
It seems like there's a lot of support in the belief that a flat top piston will yield a little bit more power than a domed piston with the same compression ratio. Kind of makes sense for mixture and more even combustion.
I think you're kind of at a point where you have to decide if you're going to go forced induction or stay naturally aspirated. A 10 to 1 compression ratio flat top piston for forced induction would be a good choice in my opinion.
Not too high. Not too low. Unless your going to run e85.
Sounds like a mean build.
Old Jul 11, 2015 | 09:01 AM
Flat top.
Old Jul 11, 2015 | 11:34 AM
hoffdaddy's Avatar
See I didn't say dome, I said reverse dome. It's like a regular f23 piston or most low compression Hondas. It's a dish with a little bump in the middle. You may have just misread. I don't have much knowledge on flat top pistons, that's the only reason I ask. I'd never use a dome unless it was my only choice. I know combustion isn't
as good with a dome as it is anything else. I use reverse dome with my turbo builds but that also doubles to lower compression.
Edit: Also does anybody know how deep the valve reliefs are cut on a k20a2 piston, h22a4 piston, or f23a1 piston whichever is deeper. I need to know because if I use aftermarket cams I'll cut them a bit deeper and use something with about the same specs as the most aggressive stock honda cam (I'll have to research, probably a k20a2, a k24a2, f20c, idk all the specs) maybe a little more aggressive since those cams are made for cars that are daily driven by a normal person. Just something in the ballpark, don't want to spend money on a custom cam.
Old Jul 11, 2015 | 03:08 PM
opps my bad. reverse dome (dish?) or flat top. I misread..
Old Jul 11, 2015 | 04:03 PM
hoffdaddy's Avatar
Yeah reverse dome is basically dish, I think reverse dome has basically replaced a true dish so most of us might call it a dish. Or maybe I just haven't pulled a dish out of an engine, all of them have a small hump in the center. I see it more commonly used so that's what I've always used. Still the question still stands flat or reverse dome/dish?
Old Jul 12, 2015 | 03:59 PM
Have you ever heard or read about setting quench clearance? Its kinda interesting.
It might answer which is better. Reverse dome or flat top.
Old Jul 12, 2015 | 04:17 PM
hoffdaddy's Avatar
I've never heard that... Sounds very interesting and right up my alley. You got any info? In the meantime I'll search Google.
Old Jul 12, 2015 | 04:45 PM
Just what I've read. Basically piston to head clearance and how different quench/squish clearances affect combustion, power, knock resistance, and emissions.
Old Jul 12, 2015 | 06:56 PM
hoffdaddy's Avatar
Ok it's everything that I thought it would be, but a stock h22 head does not have much of a quench area.
Example:
I'll have to weld the head, deck it slightly, and put a lot into polishing the combustion chamber. I was already going to polish it but now I'll have to take the new material from the welds down and shape the chamber.
It will look like this:
This doesn't sound like a bad thing lol, but it's going to raise compression, that is bad. I don't want to run 11:1 compression and I'm still leaning towards a flat top with this build. Unless I get a custom piston with the shape of my combustion chamber, I don't see any way to decrease compression with a thicker head gasket and that is the worst option, only a last resort. I'm going to use a stock head gasket. I'm worried that making dished pistons the shape of my combustion chamber are going to be really expensive. Regular custom pistons from venolia are about $400 a set... I don't think I'll be spending more than $500. If I really needed to I could weld on the top of the piston and very very carefully shape it, but I don't know if I'm that skilled
Old Jul 13, 2015 | 01:25 PM
EG1834's Avatar
A dish is just basically like a bowl whereas a reverse done is supposed to mirror the chamber shape. They're mass produced so it won't be exact, but it will be similar.
OHV Reverse Dome Piston:
OHV Dish Piston:
Old Jul 13, 2015 | 06:59 PM
hoffdaddy's Avatar
I knew the difference, I'm debating what is better.
Old Jul 13, 2015 | 07:48 PM
So I take it the reverse dome is better since it has more "squish" area? More squish=more turbulence=better mixing? From what i think I understand this is a good thing right?
Old Jul 13, 2015 | 08:59 PM
hoffdaddy's Avatar
Exactly.
Old Jul 14, 2015 | 06:35 AM
Never knew there was a difference between reverse dumb and dished pistons. I always thought they were basically the same. Thanks for learning me something new!
Old Jul 14, 2015 | 11:14 AM
hoffdaddy's Avatar
I'm pretty happy right now... If I weld my head all I need to do is make a mold of the combustion chamber and they can make any piston I could ever need for my combustion chamber. Now I just have to find out what compression ratio I want.
tofast4uh22
Jan 4, 2009 05:44 PM
Mugencrxsir1
May 2, 2006 05:16 PM
Bspec18
Oct 4, 2005 03:11 PM
Frozen E
Feb 9, 2005 09:26 AM
totalimpact
Dec 9, 2003 03:48 PM
