Replace the main caps?
Old Sep 25, 2019 | 03:49 PM
01-0720's Avatar
Default Replace the main caps?
Iv got a b18c5 block, been sitting around for years, well unfortunately some parts got separated and I'm missing the original main caps
Iv been reading around and some say, get new caps have line honed and be good
Some say they don't trust it and it won't be good
So what's the real word, can I use some main caps from another motor, because it doesn't look like I can buy these new, and then take the block to a good machine shop and they can line hone it and be good ? Is there a better solution? I mean I see 2j's with obviously not original billet mains and they are fine
So what's up can I save my block? Id really like to use it, it's out of my old itr
Old Sep 25, 2019 | 04:32 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Replace the main caps?
New main caps, line hone, call it a day.
Old Sep 25, 2019 | 08:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
There are distinct issues with replacement main caps and a line hone. The first is moving the centerline of the crankshaft by 1 to 4 thousandths up in the block. This move changes the piston-to-deck clearance, increases the chances of oil pump failure due to crank side loading, changes the relationship between cam and crank TDC by retarding the cams, and making it difficult to properly tension the timing belt.
This process is certainly possible... and depending on who you ask, acceptable. My opinion would be to get another block. Regardless of the path you choose, you now have information that helps you to decide based on facts and not simply my opinion.
toxictom
Engine Machining & Assembly
Jun 24, 2017 10:28 PM
b00stedOne
Jun 29, 2010 12:59 PM
Godspeed07
Nov 13, 2007 06:38 PM
LudeyKrus
Jan 1, 2005 05:31 PM
stayontrack
Sep 19, 2002 04:59 PM
