lsvtec timesert fail
Old Feb 25, 2021 | 10:46 AM
FloorWhore's Avatar
Default lsvtec timesert fail
ok, so heres my problem. b18a block had a few threads for head stripped out. replaced all 10 with timesert and locktite. i noticed coolant on #1 plug while looking for slight misfire. i decide to go deeper and remove head to inspect gasket/sleeve. the head bolt between #1&#2 was not tight (ARP studs) i tried to retorque with no luck. has anyone had this happen?
Old Feb 25, 2021 | 01:11 PM
FloorWhore's Avatar
Default Re: lsvtec timesert fail
Could i heat block and fill with aluminum brazing rod?
Old Feb 26, 2021 | 07:09 PM
wunfstgsr's Avatar
Loved
Community Favorite
Just find a used Ls block there cheap and a dime a dozen.
Is your LS block stock?
B20 blocks are even cheaper!
Old Feb 27, 2021 | 10:47 AM
TheShodan's Avatar
Moderator
Maybe where YOU are. Not here or in much of the Midwest
Old Feb 27, 2021 | 11:12 AM
FloorWhore's Avatar
Not very cheap here in TX. B20 is cheaper but still around$500 from salvage. Machine shop has a 4 week wait and can fill/drill/tap for $100/hole.
Last edited by tech8; Mar 1, 2021 at 01:38 PM. Reason: Inappropriate in tech section.
Old Feb 27, 2021 | 06:18 PM
wunfstgsr's Avatar
Loved
Community Favorite
HAHA! Well I guess CA is good for something!..
Old Feb 27, 2021 | 07:42 PM
FloorWhore's Avatar
I'm considering using map torch and alumaweld brazing rod. Fill hole with stud still inside. Think it may work?
Old Mar 1, 2021 | 11:10 AM
TheShodan's Avatar
Moderator
Not with the amount of forces those hold to keep that head together, no.
Old Mar 7, 2021 | 06:28 PM
FloorWhore's Avatar
i left stud and timesert in hole and melted brazing rods in the hole to fill. i was able to torque to 75 and its holding. hope ita a forever fix. thanks guys
Old Mar 7, 2021 | 08:09 PM
Ryanthegreat1's Avatar
How do you know if that is clamping force between the head and the block or just compressing the filler rod in the hole against the bottom of the head?
Old Mar 8, 2021 | 05:15 AM
FloorWhore's Avatar
I'm assuming the brazing rod has bonded with the aluminum of the block. I'm keeping close eye on it to be sure but so far it seems to be fine.
Old Mar 8, 2021 | 10:49 AM
TheShodan's Avatar
Moderator
Only way you'll know is if the stud doesn't stretch and the thread ruined.
What we typically do is get the Oversized thread kit (only the timeserts themselves) as the oversized timeserts are the same ones used in the Cadillac NorthStar V8. I picked them up from TimeSert on Amazon, so I didn't have to purchase an entire new kit.
But, you found your solution (hopefully not temporary), so, my suggestion is MOOT at this point. *shrug*
Old Mar 8, 2021 | 08:44 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Yeah I wasn't sure how you were going to be able to clean and prep down a hole to be able to get brazing to adhere. If you actually able to prep the rod and the hole properly I know the brazing would be strong enough to hold. However, I am not confident you could even remotely prep the area properly without removing exactly what you did not want to remove at all.
I wish you the best of luck in your venture.
Radyjr
Jan 12, 2010 03:55 PM
[ iLL ] iNt3GrA
Nov 16, 2009 02:34 PM
turbo Si
Dec 28, 2006 03:34 AM
H22A_HB
Mar 25, 2005 07:35 PM
hybridpatient95
24
Mar 20, 2005 05:56 AM
