Installed Morosso baffled oil pan - need two-piece lower trans brace
Hey everyone.
I just had a Morosso baffled oil pan installed on my JDM GSR swapped '93 del Sol Si (S80 ITR LSD trans). I decided to install this because I had noticed that when I'm at the track, if the oil is a little low and I'm pulling some sustained G's in a corner, the motor will sporadically drop out of VTEC. I needed to keep the oil in the pick-up to keep oil pressure up. Of course I top-up between lapping sessions.
I had the one-piece lower transmissionbrace on before the new pan was installed but I realize now that this doesn't work with the Morosso pan. From what I read on the Morosso website I need the two-piece lower transmission bracket for a b16a or b18c1.
https://jhpusa.com/products/moroso-h...affled-oil-pan
I'm going to search online for it but thought it ask if anyone knows any details about this part.
Thanks!
Thanks!
