head gasket and compression ratio
Old Jan 14, 2019 | 10:43 PM
Brembomaster's Avatar
Default head gasket and compression ratio
Hello,
I am assembling a B18c1 block with YCP 81.5 high compression piston.
what compression ratio is the limit for the b-series with the 98 octane fuel?
Is it too high if run with 12.8:1 CR? ( OEM gasket)
Thanks
Old Jan 15, 2019 | 01:08 AM
1HGEJ2's Avatar
Default Re: head gasket and compression ratio
no
Old Jan 15, 2019 | 10:06 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Depends on the fuel you want to run.
Pump gas is less forgiving to high CR.
A lot can be done by detuning but efficiency drops.
If you are using race fuel or E85, you can get high efficiency with high CR.
Old Jan 15, 2019 | 08:59 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
With a quality tune... no, 12.8:1 compression is not too high.
Acura-Power
Acura TL, RL & ZDX
May 23, 2024 05:10 PM
CALM_AS_A_BOMB
Mar 14, 2005 05:34 AM
madman604
Jun 2, 2003 11:09 AM
nd8ch
Feb 26, 2003 08:10 PM
RICHJ
Feb 18, 2003 05:48 PM
