head gasket and compression ratio
Hello,
I am assembling a B18c1 block with YCP 81.5 high compression piston. what compression ratio is the limit for the b-series with the 98 octane fuel? Is it too high if run with 12.8:1 CR? ( OEM gasket) Thanks |
Re: head gasket and compression ratio
no
Depends on the fuel you want to run.
Pump gas is less forgiving to high CR. A lot can be done by detuning but efficiency drops. If you are using race fuel or E85, you can get high efficiency with high CR. |
With a quality tune... no, 12.8:1 compression is not too high.
