B18c1 Build help
Old Aug 8, 2018 | 07:44 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Default B18c1 Build help
I currently have a 93si with b18c1 engine, it had some ring damage when I first got the engine so I tore it down and installed some JE 9.1 compression pistons with a freas hone since I knew I was installing a turbo setup. I did this setup around 15 years ago and the car has held up really well, but it’s time to make some serious power now. My question is, what compression pistons is most running (would my JE pistons serve my purpose) in these high powered setups (500-700hp) I can handle the build and I know 95% of what needs to be done to achieve my goals other than the best compression to work from and which turbo to upgrade to. My current t3t4 when I had it built was only rated to produce up to or around 350-max 400hp, I paid around 1000.00 for the turbo only and has been a great turbo. Any basic pointers would be great and appropriated.
thanks
this is my current setup, I’ve still got to reinstall my exhaust and intercooler/piping over the next few days, this setup should get me 300+whp until I get everything together to tear it back down
Old Aug 9, 2018 | 07:44 AM
DumpdEJ6's Avatar
I like the tuna here
Default Re: B18c1 Build help
From what I've seen (no personal experience) a lot of turbo guys are running around 9.5-10:1 compression.
Old Aug 9, 2018 | 08:06 AM
Chance EG's Avatar
Go 10:1 -> 10.5:1
Old Aug 9, 2018 | 09:01 AM
2x0's Avatar
2x0
10 Year Member
What fuel will you be using? Do you have a reputable tuner?
Old Aug 9, 2018 | 09:36 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
i can run 93 or e85, I know if I run e85 I will need bigger injectors. Yes I do have someone that’s experienced with the tuning which is a relief. I’d prefer to use 93 only because the car sets sometimes and I’ve heard e85 don’t like that.
Old Aug 9, 2018 | 10:12 AM
2x0's Avatar
2x0
10 Year Member
I'd stick with 10:1
Old Aug 10, 2018 | 12:08 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
What turbo does most run, seems like theses massive turbos would be hard to get spooled
HFPerformance
Apr 15, 2013 07:39 AM
Khoa_DC2
Apr 10, 2012 10:29 AM
EKB18BPR3
10
Feb 14, 2007 05:01 AM
bonez817
Dec 27, 2006 10:51 PM
95BlkGSR
Oct 26, 2004 08:15 PM
