B18 trouble
whats all the crap on cyl 2 and 3? where is piston 1 and 4? did the motor knock? is that the mains or the rod brearings that was messed up like that? did you get the hone already? that was a quick turn around.
Still waiting to hone getting block all nice and cleaned and machined those scars I'm not sure they wasn't there when I finished everything not deep though hone will take it off no knocks and those was rod bearings
Hi well let me start off by saying I rebuilt my b18b1 did everything right finished everything and put it back together and it ran like crap pulled spark plugs and had oil covered in them did a compression test and it had 65 psi in each cylinder can I get some help?!! Thanks 😄
Just some advice and don't take this negatively, but it seems like you need to take you time and double/triple check everything on the re-rebuild. It sounds like there were more than one single issue going on. Any little thing can ruin an entire engine. Something as little as .001 inches can cost big $. Clean each component inside the engine individually and as much as you can. A missed piece of metal the size of a fingernail can be the difference between a 1000 mile engine and a 100,000 mile engine. Good luck.
Thanks for the advice man I know I rushed it payed big time
cxVtecC1
Feb 18, 2005 06:54 AM
Death_to_Thieves
Sep 25, 2002 12:49 PM
