who is NOT using a distributor?
Old Jan 11, 2003 | 04:43 PM
Pelican's Avatar
Default who is NOT using a distributor?
I mean, sure it's a little more convienent, but it is more complicated, less taylorable. And has more parasitic drag.
So who ISN'T?
And would a two channel digital ignition work? wouldn't there have to be a selector for each of two banks the two coils control.
I need info.
Old Jan 11, 2003 | 04:53 PM
bambooluv's Avatar
Default Re: who is NOT using a distributor? (Pelican)
you need a trigger made up with a north and south magnet in one. IM tony1 for more info on it.-pdang
Old Jan 11, 2003 | 05:40 PM
B16A1-EF9's Avatar
I'm going to be using a coil pack. The coil I am using is setup as two coils, one for two cylinders. Although, it's only one piece both coils are together. Anyway, for me I have it running off of my standalone. I have a 60 tooth trigger wheel with a sensor on my crank pulley and that takes care of my timing and spark.
Old Jan 11, 2003 | 06:03 PM
earl's Avatar
Default Re: who is NOT using a distributor? (B16B-EF9)
Can you post a pix of your crank pulley set-up?
Old Jan 11, 2003 | 06:46 PM
Pelican's Avatar
Default Re: who is NOT using a distributor? (earl)
sweet. oh tony.....
Old Jan 12, 2003 | 02:10 AM
bambooluv's Avatar
Default Re: who is NOT using a distributor? (FastNSX)
I recently saw an ad for one that had a B series crank trigger available in their catalog. Can't remember which one it was though.....
By any chance did you see this in a tec3 add they have crank triggers available for hondas. I personally dont like the way they have the sensor mounted.-pdang
Old Jan 12, 2003 | 10:05 AM
MackSpeed-616's Avatar
this is the electromotive trigger
Old Jan 12, 2003 | 11:43 AM
dmotoguy's Avatar
Default Re: who is NOT using a distributor? (BustaNutt-616)
i dont have a distributor, but then again, my car didnt come with one
Old Jan 13, 2003 | 11:37 AM
paulzy's Avatar
are those universal? Meaning, can I use the electromotive on say an AEM, haltech, or FAST unit?
Old Jan 13, 2003 | 04:32 PM
Pelican's Avatar
Default Re: who is NOT using a distributor? (1320development)
Paul!!!
Always copying my ideas.
Just Playin
EDIT: Ah, and thanks to you and Louis for the Snail
[Modified by Pelican, 8:33 PM 1/13/2003]
Old Jan 13, 2003 | 04:54 PM
paulzy's Avatar
Paul!!!
Just Playin
No problem mang...Naw, I've been thinking about this for ages. I've been contemplating teh SDS system for a couple years now.
http://www.sdsefi.com
Old Jan 14, 2003 | 05:14 AM
newspeedR's Avatar
Has any 1 though about incorporating the stock Honda CFK sensor as a pickup as a crank angle.
Only thing is would have to reconfigure the ecu setup for a smaller diameter and different amount of teeth unless it is modified...
Old Jan 14, 2003 | 05:19 AM
B16A1-EF9's Avatar
Here is my setup for my DTA system.
[Modified by B16B-EF9, 9:19 AM 1/14/2003]
Old Jan 14, 2003 | 08:25 AM
s2k1's Avatar
I don't run a distributor on my boosted H23. I run individual coils on each plug, no coil packs. I don't use late model Honda coils because they have ignitors built in and an MSD won't fire them. I run an Autronic SMC ecu along with an MSD DIS4. My ecu uses 1 hall effect sensor on the crank and 1 on the intake cam. I biult the trigger wheels and sensor brackets myself. The cam trigger sticks out of the back of the head where the cam plug normally resides. The crank trigger wheel bolts to the back of an Unorthodox crank pulley. It works sweet.
My boosted S2000 motor uses the same coils and ecu/ignition setup. (I don't use the S2000 coils because of the ignitors)
Old Jan 14, 2003 | 06:33 PM
1fasttoy's Avatar
What type of computer are you running? I have a Haltech with two MSD 6A boxes and four coils. I will post pics of my modified dist. I called Electromotive and they stated that I could not use there setup with my Haltect, I don't know about others.
Old Jan 14, 2003 | 06:51 PM
paulzy's Avatar
who know's Rosado racing's phone number? I know they modify factory distributors for individual coils
Old Jan 15, 2003 | 07:01 AM
1fasttoy's Avatar
Rosado Racing in Florida?
Old Jan 15, 2003 | 08:26 AM
paulzy's Avatar
Default Re: who is NOT using a distributor? (1fasttoy)
yeah
Old Jan 15, 2003 | 10:11 AM
ScrapinSi's Avatar
wait a minute here... At my work, we build these paper folders, and they have a COG Gear on them, with a magnetic pickup to adjust speed... Now, can i take one of those cog gears w/ the magnetic pickup, modify the distributor so the cog goes on the cam where the distributor would normally hookup, and run the magnetic pickup to an MSD Digital Box? Does the cog need to be a certain size? what size would it need to be?
welltal89
10
Apr 4, 2010 03:11 PM
AutoLab
Jan 15, 2008 06:33 PM
silent-chris
Feb 27, 2005 06:41 PM
