Where to Start
Old Nov 27, 2006 | 06:17 PM
beefalobart's Avatar
Default Where to Start
90 Integra 3door GS, stock engine (b18a1 if not mistaken) stock body, well just bone stock.
Car Use: 1/8th mile Strip Only no 1/4 mile, no road/street use at all.
Target Goal: Run a 10.5" slick, Run in the sub 6 second runs.
Current build Plan: JDM 98 GSR, Unknown brand Turbo Kit, Nos kit.
I know I need to and will be removing as much weight as I can, so that I can meet the weight restrictions (not sure of weight) by adding weight where Its needed for best performance.
What I need is a solid build plan and what items I need to purchase to get to my Target Goal. I need the major parts list, not every nut and bolt, like what Engine, spool or LSD, suspension setup, Turbo brand and turbo parts like BOV and others. What head work like port/polish, what cams, what TB, intake, so on. I have til feb to get this car track worthy, so time is on my side, just need to get a grasp on what budget I need to obtain in my toy fund. I will also be looking into local sponsors for some of the money.
Thanks I look forward to seeing some good posts here.
Old Nov 27, 2006 | 06:25 PM
GrinderGuy2's Avatar
Default Re: Where to Start (beefalobart)
good luck running sub 6 second 660's lol
and good luck running a 10.5 tire
and good luck doing it all before february
Old Nov 27, 2006 | 06:27 PM
miller's Avatar
Default Re: Where to Start (GrinderGuy)
10.5" tire, damn that would be nice.
Old Nov 27, 2006 | 06:31 PM
Default Re: Where to Start (miller)
sub 6 second 660's would be nicer lol.. well on a streetcar
Old Nov 28, 2006 | 06:26 AM
underpressure02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beefalobart &raquo;</TD></TR><TR><TD CLASS="quote">90 Integra 3door GS, stock engine (b18a1 if not mistaken) stock body, well just bone stock.
Thanks I look forward to seeing some good posts here.</TD></TR></TABLE>
Dam man you need a lot. Better start searching.
Old Nov 28, 2006 | 03:21 PM
Default Re: Where to Start (underpressure02)
Lifted this from the CRX Raffle post, but is this a good start and where could I go from there to get this as good as possible for the 1/8th mile strip.
Engine:
Hasport EFB2 mount kit with Hydraulic clutch conversion
B18C block with B16A head
Integra Type R intake and exhaust cams
Integra Type R valve springs
Full Race Stage 1 turbo with
Garrett T3T04E turbo, 51 compressor trim and .63 A/R turbine housing
44mm Tial wastegate
50mm Tial blow-off valve
JG Edelbrock Victor-X intake manifold
RC Engineering 1000cc injectors
TurboXS 4 stage boost controller
STR adjustable timing gears
Transmission:
Integra Type R transmission with limited slip differential
EXEDY Twin disc clutch
Driveshaft Shop Stage 4 axles.
Engine Management:
GM 3 bar map sensor
Locash Racing OBD0 to OBD1 adapter harness
Hondata S300 ECU
Suspension and wheels:
Progress Competition Coil-overs
Circle lightweight 13x7 steel wheels front
M&H Racemaster 8x25.0x13 drag slicks
Konig Traffik 15x6 1/2 wheels rear
Dunlop Sport 9000 205/50SR17 tires
Chassis:
Custom ABS front splitter
Fiber Images Carbon Fiber hood
Modified Autopower Industries rollbar
Kirkey aluminum race seat
Let me know where to go from there and what could be changed.
Old Nov 28, 2006 | 03:29 PM
did u just copy that from that hasport car? lol its a lil more complicated then that man.. nevermind
Old Nov 28, 2006 | 03:32 PM
Desir Performance's Avatar
wow, you need a lot of help, keep reading and try to get an idea of what you want. If i was you i would go into the Forced Induction section and select All in the date category and start reading.
Old Nov 28, 2006 | 04:42 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">10.5" tire, damn that would be nice. </TD></TR></TABLE>
yeah really.......
my best so far was a 6.95.
hey miller, you guys making the pan w/ the 2" lip yet?
Old Nov 29, 2006 | 05:23 AM
boostfeen's Avatar
...lol.
...drop off car at NRG with a major credit card that has a 30k$ limit and then pick car up in feb. and you will have a track worthy car.
..other than that, good luck getting, and building all that in two months.
Old Nov 29, 2006 | 06:02 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrinderGuy &raquo;</TD></TR><TR><TD CLASS="quote">good luck running sub 6 second 660's lol
and good luck doing it all before february</TD></TR></TABLE>
we have been 5.8 in the 1/8
Old Nov 29, 2006 | 06:05 AM
jjspec's Avatar
Default Re: Where to Start (dturbocivic)
What class/ racing organization are you planning to run?
Old Nov 29, 2006 | 08:08 AM
quickda6's Avatar
Ive been under 6's on an 11.5in tire. Just not on my honda
Modified by quickda6 at 1:00 AM 12/1/2006
Old Nov 30, 2006 | 08:01 AM
DaveF's Avatar
Default Re: Where to Start (jjspec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjspec &raquo;</TD></TR><TR><TD CLASS="quote">What class/ racing organization are you planning to run?</TD></TR></TABLE>
us or the original poster ?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quickda6 &raquo;</TD></TR><TR><TD CLASS="quote">
Ive been under 6's on an 11.5in tire. Just not on my honda </TD></TR></TABLE>
on or in what ? your GF ???
Old Nov 30, 2006 | 08:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
we have been 5.8 in the 1/8 </TD></TR></TABLE>
yah, i said it would be nice on a streetcar.. its do-able on bars
Old Nov 30, 2006 | 09:26 AM
jjspec's Avatar
[QUOTE=dturbocivic]
The original poster
Old Nov 30, 2006 | 09:29 AM
dkim48's Avatar
how are you not banned grinder guy?
Old Nov 30, 2006 | 09:46 AM
Default Re: Where to Start (dkim48)
The same reason your not banned..
People make mistakes.
Old Nov 30, 2006 | 10:03 AM
dmotoguy's Avatar
did you ever finish the white coupe you were working on? it was clean
Old Nov 30, 2006 | 10:06 AM
Default Re: Where to Start (dmotoguy)
it was sold a while ago and some of the money was donated to the fund.
thanks for the compliments.. Id like to get off that subject tho..lol
Old Nov 30, 2006 | 10:08 AM
dmotoguy's Avatar
What I need is a solid build plan and what items I need to purchase to get to my Target Goal. I need the major parts list, not every nut and bolt, like what Engine, spool or LSD, suspension setup, Turbo brand and turbo parts like BOV and others. What head work like port/polish, what cams, what TB, intake, so on. I have til feb to get this car track worthy, so time is on my side, just need to get a grasp on what budget I need to obtain in my toy fund. I will also be looking into local sponsors for some of the money..</TD></TR></TABLE>
dont try to do it all at once, first turbo your car.. get it tuned...run it..then get some slicks.. figure out the cars weaknesses and go from there.. let the car evolve as you learn and figure out what you are doing.
dont worry about sponsors for atleast few seasons.
good luck
Old Nov 30, 2006 | 10:28 AM
adrenalinjunkie's Avatar
I will also be looking into local sponsors for some money.Good luck on that dude.You and every other racer would like some money for free.I don't even think the top pro's recieve money.Maybe parts,for free and than sell the parts for money.Any way good luck on your project.
Old Nov 30, 2006 | 11:15 AM
quickda6's Avatar
on or in what ? your GF ??? </TD></TR></TABLE>
Eh, just a 3800lb luxury car
Old Nov 30, 2006 | 01:26 PM
DaveF's Avatar
Default Re: Where to Start (quickda6)
Eh, just a 3800lb luxury car </TD></TR></TABLE>
*hides under computer desk* not that sc ??
Old Nov 30, 2006 | 04:01 PM
quickda6's Avatar
*hides under computer desk* not that sc ??</TD></TR></TABLE>
See you at the track my friend
