wastegate/c02 ?
Old Jan 30, 2008 | 08:00 AM
88 yellow crx's Avatar
Default wastegate/c02 ?
Been searching for companies making c02 systems used to control wastegates and can't find anything. Can someone steer me in the right direction on what to buy.
Old Jan 30, 2008 | 09:05 AM
Innes's Avatar
Default Re: wastegate/c02 ? (88 yellow crx)
Dedenbear has the co2 kits
http://www.dedenbear.com/C02BTL_cat.htm
that is the setup we ran the last couple of years
Old Jan 30, 2008 | 10:36 AM
Default Re: wastegate/c02 ? (Innes)
Thanks for the info James.
Old Jan 30, 2008 | 05:55 PM
Jared's Avatar
no need if your turbo is sized properly
Old Jan 31, 2008 | 08:02 AM
Default Re: (Jared)
Needed because I'm going to be running ams-1000. And c02 is alot more responsive and can get the boost were I want it. Right know I'm using a turbo xs quad stage and a .7 spring in the gate and cant get over 23 lbs. Also my motor is 2.1 with a GT35r.82 so I dont think turbo sizing is the problem.
Old Jan 31, 2008 | 11:21 AM
Boner_Ben's Avatar
Default Re: (88 yellow crx)
With a 10 psi spring I can get almost 40 psi with the NLR without c02.
Old Jan 31, 2008 | 03:04 PM
Jared's Avatar
im running 8psi springs and it will make 8psi on the gate and 39psi with 50.39% duty on the solenoid with only using manifold pressure.
Old Jan 31, 2008 | 04:00 PM
Default Re: (Jared)
I know you can make boost without. But the tuner would perfer using c02.
Old Jan 31, 2008 | 04:14 PM
Turbo-charged's Avatar
nlr strongly suggests using c02 with their controllers
Old Jan 31, 2008 | 04:37 PM
SpeedDreamz.com's Avatar
Default Re: (Turbo-charged)
how long does a 10oz tank of co2 last?
Old Jan 31, 2008 | 05:16 PM
tokesGTR's Avatar
Default Re: (SpeedDreamz.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">how long does a 10oz tank of co2 last?</TD></TR></TABLE>
I'm wondering as well!
And how hard would it be to swap between CO2 and manifold pressure on the NLR?
Old Jan 31, 2008 | 05:32 PM
Default Re: (tokesGTR)
the bottles will last you all weekend as long as you turn the bottle off between rounds/over night.
its easy to swap between manifold pressure and co2 as long as you set it up where you can cap off the manifold pressure source easily when you are using c02. you wont have to cap off the c02 line, just turn off the bottle.
Old Jan 31, 2008 | 05:55 PM
I was also told if using a tial wastegate it will have to be modified to use c02. Is this true?
Old Jan 31, 2008 | 06:22 PM
HR-1320's Avatar
Just honda bond the seal under the cap of the tial gate.. I leave my bottle on all weekend and dont change it.
Modified by HR-1320 at 10:56 PM 1/31/2008
Old Jan 31, 2008 | 06:49 PM
Innes's Avatar
Default Re: (HR-1320)
yeah the 10 oz bottles will last a long time -- we just used the co2 in 3rd and 4th gear and i bet if we added up the potential of runs on a bottle it would be 25+ -- we forgot to close the bottle sometimes and it would slowly leaked out -- solved that potential issue with a spare full 10 oz bottle in the trailer at all times just in case
Old Jan 31, 2008 | 07:00 PM
Default Re: (Innes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innes &raquo;</TD></TR><TR><TD CLASS="quote">yeah the 10 oz bottles will last a long time -- we just used the co2 in 3rd and 4th gear and i bet if we added up the potential of runs on a bottle it would be 25+ -- we forgot to close the bottle sometimes and it would slowly leaked out -- solved that potential issue with a spare full 10 oz bottle in the trailer at all times just in case</TD></TR></TABLE>
you guys forgot to open the bottle b4 too, right?
Old Feb 1, 2008 | 09:45 AM
Innes's Avatar
you guys forgot to open the bottle b4 too, right? </TD></TR></TABLE>
yes, several times
ferguson and i got a system to remind each other now though
Old Feb 1, 2008 | 09:58 AM
tony1's Avatar
Default Re: (Innes)
That's why i don't use it, forgot to open the bottle a couple times on Kenny's car and it cost us a race.
Old Feb 1, 2008 | 10:22 AM
TiAL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 yellow crx &raquo;</TD></TR><TR><TD CLASS="quote">I was also told if using a tial wastegate it will have to be modified to use c02. Is this true?</TD></TR></TABLE>
no
Old Feb 1, 2008 | 10:41 AM
miller's Avatar
Default Re: (TiAL)
a little honda bond fixes everything!
Old Feb 1, 2008 | 10:51 AM
TheWickedOne's Avatar
Default Re: (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">a little honda bond fixes everything!</TD></TR></TABLE>
So true.., one of the most important things a racer should bring to the track, along with Zip Ties.
Old Feb 1, 2008 | 11:45 AM
boosted hybrid's Avatar
Default Re: (TiAL)
I know for a fact that you have to honda-bond the diaphram to the lip on the valve hat (i dont know what exactly to call it) with the 44mm gates. When we ran 3psi wastegate springs in dual gates two seasons ago with the ams-1000, with 50-60psi of c02 pressure the diaphram would pull apart from the valve hat. It would do it within a few pulls on the dyno, and typically 1-2 passes at the track. The key to modifying the gate is to spread the honda-bond on both sides of where it tucks into the lip, and put alot of it. I let it cure for over a week, and never had a single issue after that. Our 60mm Tial gate that we ran last year was not modified, and didnt have any issues at 30-40psi of co2 level.
5557billetwheel
May 7, 2010 07:03 PM
eulises08
Sep 9, 2009 09:39 AM
SilverCoupeEj8
Jan 15, 2007 09:22 AM
rice is nice
Aug 24, 2005 09:39 AM
MostlyR
Nov 14, 2004 01:48 AM
