transmission question
Old Feb 9, 2005 | 03:09 PM
teglsturbo's Avatar
Default transmission question
how much power will a stock ls transmission reallistically hold?
Old Feb 9, 2005 | 03:25 PM
paulzy's Avatar
Default Re: transmission question (teglsturbo)
at least 500whp if taken lightly out the hole
Old Feb 9, 2005 | 03:26 PM
teglsturbo's Avatar
Default Re: transmission question (paul vang)
do you think it would hold 700whp? if not does someone make a gearset for them that will?
Old Feb 9, 2005 | 03:36 PM
ssc_thomas's Avatar
The stock trans is a strong unit. 2nd and 4th gear are going to be your problems.
I feel that a stock honda trans will work just fine at those kind of numbers. Tire size is a big part of your question as well.
There are some aftermarket gear sets out there but none that have proven to not be problematic in the same areas as the stock gears. Costs on these gear sets is a big factor to, because they are quit pricey.
I say if it's a street car pop an lsd in the thing pair it with some good axles and clutch and go tear the strip up. If a racecar get ya a spool and the rest the same
Old Feb 9, 2005 | 04:05 PM
teglsturbo's Avatar
Default Re: transmission question (ssc_thomas)
have you tried a phantom grip on those kinds of numbers?
Old Feb 10, 2005 | 09:28 AM
procarguy's Avatar
great
Old Feb 10, 2005 | 11:22 AM
ssc_thomas's Avatar
phantom grips don't tend to do so hot with those kit of numbers but it has been awhile since we've ran one in anything that high. I here with the upgraded springs and diff saver stuff that they hold quite a bit.
EJ8 GSR-T
Honda S2000
10
Mar 19, 2009 02:20 PM
slooogsr
Aug 21, 2006 07:00 AM
BoostR41
Nov 14, 2005 09:52 AM
Drew Peacock
Oct 20, 2002 10:28 AM
