traction bars... wtf is going on?
Old Mar 24, 2007 | 07:37 AM
rebo0t's Avatar
Default traction bars... wtf is going on?
z10 bars.. last night dropped in the motor and noticed that the oil pan was hitting the bar? whats going on? the car has never been in an accident and all motor mounts (prothanes) fit fine. did i install it to the correct point on the LCA? the z10 instructions are not too clear on if i was suppose to mount it to the center of the LCA or the strut fork bolt. btw, dont mind the mess.. got a new oil pan to replace it.
Modified by rebo0t at 9:19 AM 3/24/2007
Old Mar 24, 2007 | 08:02 AM
Big Teggie's Avatar
Default Re: traction bars... wtf is going on? (rebo0t)
You have them mounted to the wrong location on the LCA.
The U sahped bracket needs to be mounted to the where the shock fork connects to the LCA. That will solve your problem, and is how the Z10's are designed to work.
Old Mar 24, 2007 | 08:18 AM
rebo0t's Avatar
thought so.. the instructions said on the LCA, but it didnt specify the strut/shock fork. plus from other pictures maybe other brand of traction bars. i see some are mounted on the LCA. oh well, i will try again tonight. thanks
FOMULA91
Feb 21, 2015 03:39 PM
iceman7329
14
May 3, 2007 05:52 PM
Tippyman
Welding / Fabrication
22
Oct 21, 2006 02:24 PM
99SilverBullet.b45!
20
Sep 25, 2006 08:28 AM
atisvt99
Jul 9, 2002 06:33 AM
