traction bars
Old Feb 23, 2004 | 11:00 AM
B18CR-X's Avatar
Default traction bars
are traction bars relly worth it or should i get some better struts and what kind, cause every time i launch my car it just starts will hoping. thanks.
Old Feb 23, 2004 | 11:36 AM
DaveF's Avatar
Default Re: traction bars (B16SI00)
the traction bars will help the control arms from deflecting. and will help stop wheel hop if set up properly.
goodluck and try the search button....it works wonders.
Old Feb 23, 2004 | 06:11 PM
Savalicious's Avatar
Traction bars will definately work but be careful of which ones to get some do not have the correct geometry and can cause damage to suspenion parts causing and unsafe situation. Geoff from full-race will be posting picks soon of my traction bars from last season and you can see the lower control arms got bent from the wrong geometry, full-race will soon be releasing their version called Strip Bars with the proper geometry.
Old Feb 23, 2004 | 06:28 PM
DaveF's Avatar
Default Re: traction bars (LeoneRacing)
hows your car coming along, sav ??
Old Feb 23, 2004 | 06:42 PM
Default Re: traction bars (2.2Lcivic)
Car is awsome!! can't wait to paint it and get it running. Geoff and everyone at full-race did super getting it together. pics will be up soon.
Old Feb 23, 2004 | 06:54 PM
DaveF's Avatar
uh oh....gonna be a top contender this season ?? what "series" you plan on running? nopi ? i hope its not idrc.
Old Feb 24, 2004 | 07:51 PM
Full-Race Geoff's Avatar
https://honda-tech.com/zerothread?id=778517
Old Feb 25, 2004 | 07:01 PM
hair_rice's Avatar
how are the lakewood traction bars seen in the summit racing pages in all teh mags?
Old Feb 25, 2004 | 09:37 PM
E-Town4229's Avatar
Default Re: traction bars (hair_rice)
nice stuff geoff!
-Roger
Old Feb 26, 2004 | 06:07 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hair_rice &raquo;</TD></TR><TR><TD CLASS="quote">how are the lakewood traction bars seen in the summit racing pages in all teh mags?</TD></TR></TABLE>
pay no mind to those bars..... if they were thinking when they built them, they wouldnt look the way they do...the bars have NO THOUGHT put into them...
on the other hand.... FULL RACE BARS, are properly engineered. and alow for a full suspension travel with no binding. also allow for "lock to lock" steering with out hitting the bars.
Old Feb 26, 2004 | 03:17 PM
Default Re: traction bars (Dturbocivic)
thanks dave
Old Feb 26, 2004 | 05:04 PM
DaveF's Avatar
Default Re: traction bars (Full-Race Geoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">thanks dave</TD></TR></TABLE>
no prob.
forgot to mention...that the FULL RACE bars.will NOT have any adverse effects on the suspension bushings.
Modified by Dturbocivic at 9:24 PM 2/26/2004
Old Feb 27, 2004 | 05:35 AM
B18CR-X's Avatar
are the z10eng bars any good
Old Feb 27, 2004 | 05:47 AM
DaveF's Avatar
Default Re: (B16SI00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16SI00 &raquo;</TD></TR><TR><TD CLASS="quote">are the z10eng bars any good</TD></TR></TABLE>
the z10 bars do what they were designed to do, and that is to stop the lower control arms from flexing under "launch/ load" conditions. according to some sources on the "net" they are not "properly aligned" to keep the suspension from binding when it goes through its range of motion... and it has also been said that by mounting the bar to the lower "shock fork bolt" it will eventually tear up the bushing, but there is another bolt to the inside of the shock that will work perfect for our applications.
what i mean by not "properly aligned" is the mounting location of the bar that runs diagonal between the front crossmember and the lower control arm. the front mounting point is NOT inline with the mounting point of the lower control arm, where it gets bolted to the subframe.... again.. this has been said to "bind" when the suspension goes though its range of motion..and might possibly cause unexpecting reactions from the front of the vehicle..
goodluck with whatever the choice may be.
Old Feb 27, 2004 | 10:28 PM
96dc2's Avatar
Default Re: (Dturbocivic)
How do the Full-Race compare to the JimFab's?
Old Feb 28, 2004 | 04:41 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: (96dc2)
From my research, the Full-race bars are of better quality than the Jim Fab's. Full-Race uses a higher quality heim joint, that will not rattle or squeak over time. The attachment points are 1/4" chromoly, not 3/16" mild. The Full-Race bars are 100% tig welded, where the jim fabs are mig welded, and the Biggest bonus about the Full-race bars is that they will clear a 3" down pipe or a big all motor header, as the guys over at Full-Race put the thought into it, and moved the front cross member forward.
HTH
Clayton
Old Feb 28, 2004 | 11:01 PM
Default Re: (Clayton)
damn you did your homework!
Old Feb 29, 2004 | 06:11 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: (Full-Race Geoff)
I told ya Geoff, you can't do what I do half assed. You have to have all of your info. I can't wait for the backorders to clear to try these bad boys out for myself. Then I can offer a full review. Mind if I get the welds X-Ray'd to show the true strength???
Clayton
SOLtrain "tiiiteboyee"
Jan 24, 2008 03:42 AM
Red_ED8
Sep 26, 2006 10:36 AM
92hatchattack
Suspension & Brakes
Jul 10, 2006 06:46 AM
16vt
Welding / Fabrication
May 9, 2005 08:01 PM
mrbsponge
Suspension & Brakes
Mar 14, 2005 08:22 AM
