At the track with radials= problems
Old Aug 31, 2010 | 06:24 PM
8urv8's Avatar
Default At the track with radials= problems
I wanted to try something different on my car so i went with the M/T 235/60/15 et drags, the problem is when I go into 2nd gear the car goes to shaking to the point where i would almost half to let of. Its not wheel hop, its more like a wobble and I half to fight the wheel to keep it straight. This goes on all the way down the track. It does fine with slicks.
The setup
D16Y8 409hp
s40 tranny
Went from 20psi down to 12 1/2psi and sill the same
comp stage5 clutch
Their is no loose parts ect in front end and alignment before the track.
traction bars
Quaif LSD
Any info would be helpful to cure this problem!
Old Aug 31, 2010 | 07:26 PM
blackeg's Avatar
Default Re: At the track with radials= problems
same wheels as the slicks? were they balanced when mounted?
side note, if those tires are like bfg radials, you can go down to like 9-10 psi with them and see better results
Old Aug 31, 2010 | 07:37 PM
8urv8's Avatar
No diffrent rims for the slicks. Yes they were balanced when mounted and i re checked them today.
Old Aug 31, 2010 | 09:33 PM
Dark_Teg's Avatar
I was running Mickey thompson ET drag radials 295/45/17's on my Mustang and had the same issue during the burnout and if I had first gear spin. The Mickey thompson radials have a very stiff sidewall. Even when I would drop the pressure to 12 psi they still looked fully inflated. I went to some 11.5X26X17 ET streets (the old school version) and the problem went away.
Old Sep 1, 2010 | 03:16 AM
vectorsolid's Avatar
I had a similar thing happen last weekend. But instead of a drag radial or my usual M&H slicks. I decided to make a pass on my dunlop slicks I SCCA race with. Firstly, the worst 60's EVER with that car, and it shook like you were describing on the 1-2 shift, a LOT. To the point I "almost" got out of it but didn't. I've got over 100 passes in the car, and my tires caused whatever it was. Don't know the explanation though.
But I'm done using those tires at the strip. They were on the car and I thought, "what the heck... how bad could it be they're slicks?" it was bad...
Old Sep 1, 2010 | 05:38 AM
QUICK8CIVIC's Avatar
Try to check your hub mating surface for flatness.there are instances where the hub has hard dirt e.g. hard rust that will form a space in between your wheel and hub when mounted..put your car on a lift and try to rotate the front tires and check for alignment when it spins.
Old Sep 1, 2010 | 09:38 AM
8urv8's Avatar
Yea I work at a automotive shop and we had it on the rack this morning and we did all that. I really think it's just the tires because I've had these rims in the car for awhile until I had the radials mounted on them then this happen. It may just be that the car is spinning real bad with the quaif and one side grabs and the other does not idk that's all I can think of at this point.
Old Sep 1, 2010 | 10:10 AM
DC5TypeS02's Avatar
Pretty sure a tire used for SCCA prob has a very stiff sidewall so no good for drag but you know what now
96_civic_EX
Oct 12, 2010 10:57 PM
crazy eyez killa
Nov 26, 2003 03:42 PM
Adub33
15
Jul 10, 2003 04:18 AM
89civic1.8T
Nov 9, 2002 10:27 AM
scrubachu
May 30, 2002 02:15 PM
