TPS Issue
Old Oct 13, 2010 | 07:50 PM
lsvegmatt's Avatar
Default TPS Issue
So after running 11.5 index a month ago at the nscra event my car through a check engine light in eliminations and fell on its face putting me in the loser spot very quick... Here a month later i finally got to fixing the issue since painting the car came first. Code 7 (tp sensor) was on so i first thought of just replacing the tp sensor. Got one, took the "faulty one" off and oh hey a spring and retainer popped out. Since the spring retainer inside looks to be pressed on my question is this.... Can i put the spring back on correctly and hold the retainer on and put a quick small weld on it? I dont see why not but was curious to see if anyone has done so. Thanks for any help. Also added was a picture for anyone curious on how to remove a tp sensor. Dremel and flat head screw driver, Get deep enough to where the flat head doesnt strip it out and there ya go. Replace with philips/flat/hex whatever for easy removal next time.
Old Oct 14, 2010 | 06:07 PM
lsvegmatt's Avatar
Default Re: TPS Issue
41 views and no reply. Guess no one has had this problem, so thanks to no one blowing my post up with false info. I fixed it and here is the pic. Hopefully it holds up.
knboard
Honda CR-V & Element
May 12, 2018 10:19 PM
c0d0r
May 5, 2009 01:07 PM
i64X
Nov 11, 2003 07:12 AM
