tilton twin disk problems
Old Aug 28, 2004 | 01:30 PM
JDogg's Avatar
Default tilton twin disk problems
the damn thing wont disenguage at all....
it sounds like it is, but wont go in gear at all and drags the car around if you put it in gear and crank it up... the slave is getting the full movement, there is no more adjustment in anything..
anyone have any idea wtf is up w/this thing
Old Aug 28, 2004 | 01:45 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: tilton twin disk problems (JDogg)
What throw out bearing are you using?
Old Aug 28, 2004 | 02:19 PM
Jockobo's Avatar
Default Re: tilton twin disk problems (Arturbo)
can u attemp to drive it around a little? that happened with us and driving it loosened it up...
Old Aug 28, 2004 | 03:10 PM
Suprdave's Avatar
Do yu have a pedal stop? Might have overstroked it and fucked up the plate.
Old Aug 28, 2004 | 05:05 PM
JDogg's Avatar
Default Re: tilton twin disk problems (Suprdave)
we are using the stock throwout bering with teh tilton master cylinder. we had the hydrolic t/o bering in there, but it leaked and didnt work right.
i didnt do the orignal install so im not sure about the pedal stop... when i first got the engine running it wouldnt go into gear.. i tried not pushing it in all the way, but i guess the damage would have already been done.
it feels like its working and i hear the steels ratteling, but it just dosnt disenguage
Old Aug 28, 2004 | 05:09 PM
Arturbo's Avatar
Better than steak
25 Year Member
Did you grind out the plastic of the stock throw out bearing?
Old Aug 28, 2004 | 05:38 PM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Did you grind out the plastic of the stock throw out bearing?</TD></TR></TABLE>
hmm... dude that installed it probably didnt, didnt know we were supposed to.
Old Aug 28, 2004 | 05:44 PM
Arturbo's Avatar
Better than steak
25 Year Member
Eventualy the plastic will be eaten up, but you need to grind it flush with the bearing. and dont forget about the pedel stop. The way to do it is have the pedel stop 1/4" before it fully engages.
Old Aug 28, 2004 | 11:10 PM
JDogg's Avatar
i talked to the guy that orignally installed the clutch..
the plastic was grinded off the t/o bering... it was all chewed up from the previous install anyway.. (the clutch worked great on the other car.. which had the same exact setup and it worked great... wtf? )
as far as the pedal travel... w/the stock master cylinder it wouldnt disenguage at all.. couldnt hear the clutch chatter at all w/the pedal in. we put in the tilton M/C and it seemed to work better, but still wont go into gear.
we will probably rip the tranny off next week and see what we can see... still odd to me.. the exact same setup worked fine in the old hatch....
Old Aug 29, 2004 | 01:00 AM
Arturbo's Avatar
Better than steak
25 Year Member
Hmm, you got me then...lol Sorry I couldnt help out.
Old Aug 29, 2004 | 05:22 AM
FastEK9's Avatar
Make sure your disc(s) were install the correct way.
Old Aug 29, 2004 | 10:15 AM
ninesecteg's Avatar
Default Re: tilton twin disk problems (FastEK9)
yeah what he said!
Old Sep 7, 2004 | 02:57 PM
Blind-Fashion's Avatar
updates?
Old Sep 7, 2004 | 04:15 PM
JDogg's Avatar
Default Re: (Blind Fashion)
we took it out.. looks like the 2nd disk wasnt lined up properly and the splines were buggerd up. when they tightened down the tranny it looks like it was pushing the 2nd disk into the flywheel. pulled it out and stuck an act xtr6 in there.. this motor isnt going to be making the power the old one was.
M2nR
19
Jun 23, 2009 11:19 AM
250r king
Feb 16, 2009 05:35 PM
freshvibes
Mar 7, 2006 11:23 AM
civicstar
Jan 26, 2006 05:41 PM
982drLS
Jun 12, 2004 04:44 PM
