Tilton flow installed
Old Aug 20, 2008 | 06:25 PM
1junkycivic's Avatar
Default Tilton flow valve installed
Anyone have pics of flow valve installed with stock slave cylinder?
Modified by 1junkycivic at 7:34 PM 8/20/2008
Old Aug 20, 2008 | 07:57 PM
BlakeJ53's Avatar
Default Re: Tilton flow valve installed (1junkycivic)
What is your email adress I can send you some. I ran a -3 steelbraided line from the clutch mastercylinder to the slave cylinder and used a -3 to -3 female union off of the slave cylinder and put it in line with that.
Old Aug 20, 2008 | 07:59 PM
Default Re: Tilton flow valve installed (BlakeJ53)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlakeJ53 &raquo;</TD></TR><TR><TD CLASS="quote">What is your email adress I can send you some. I ran a -3 steelbraided line from the clutch mastercylinder to the slave cylinder and used a -3 to -3 female union off of the slave cylinder and put it in line with that.</TD></TR></TABLE>sent
Old Aug 21, 2008 | 04:29 AM
miller's Avatar
what clutch are you using?
Old Aug 21, 2008 | 05:13 AM
blueshark123's Avatar
Default Re: Tilton flow valve installed (miller)
How are you guys liking the tilton flow valve? I have the tilton cmc with a CC twin disc and Ive been wondering if I would benefit from it...
Old Aug 21, 2008 | 06:26 AM
miller's Avatar
Default Re: Tilton flow valve installed (blueshark123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueshark123 &raquo;</TD></TR><TR><TD CLASS="quote">How are you guys liking the tilton flow valve? I have the tilton cmc with a CC twin disc and Ive been wondering if I would benefit from it...</TD></TR></TABLE>
I wouldnt do that. You might be buying a new clutch if you do.
Old Aug 21, 2008 | 07:12 AM
BlakeJ53's Avatar
QUOTE=miller]
I wouldnt do that. You might be buying a new clutch if you do.[/QUOTE]
Please elaborate.
Old Aug 21, 2008 | 07:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">what clutch are you using?</TD></TR></TABLE>exedy
Old Aug 21, 2008 | 07:45 AM
I wouldnt do that. You might be buying a new clutch if you do.</TD></TR></TABLE>
Yeah please elaborate.
Old Aug 21, 2008 | 07:49 AM
miller's Avatar
If you are using a carbon plate setup it is possible to use this and it wont effect the disks with the slippage as the heat really doesnt effect them. I have tried this with the metallic disks and have had issues of plates melting and chunking off along with warping the floaters.
Old Aug 21, 2008 | 07:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">If you are using a carbon plate setup it is possible to use this and it wont effect the disks with the slippage as the heat really doesnt effect them. I have tried this with the metallic disks and have had issues of plates melting and chunking off along with warping the floaters.</TD></TR></TABLE>What size orifice used?
Old Aug 21, 2008 | 08:29 AM
Innes's Avatar
news to me -- we have used it for 2 years without a problem on a tilton cerametallic twin
Old Aug 21, 2008 | 08:35 AM
miller's Avatar
Default Re: Tilton flow valve installed (Innes)
we had the smallest orifice installed at the time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innes &raquo;</TD></TR><TR><TD CLASS="quote">
news to me -- we have used it for 2 years without a problem on a tilton cerametallic twin </TD></TR></TABLE>
It may be that the tilton can deal with it and the others cant.
Old Aug 21, 2008 | 08:41 AM
redboost10's Avatar
been using the flow valve with my tilton cerametallic with no problems also.
jdm kidd
Jan 15, 2011 06:07 AM
rhdins
Nov 3, 2009 03:22 AM
Turbocivic94
May 30, 2006 02:11 PM
GWInquisitor14
Apr 6, 2005 03:38 AM
OBDII Integra
Oct 20, 2004 11:47 AM
