Sump to Pump location
Old Dec 21, 2010 | 07:56 PM
SPOOLINmatt's Avatar
Default Sump to Pump location
this is probably an idiotic question but. I have an FCS fuel cell, and i want to mount my aeromotive pro pump forward of the cell basically in "front" of it where the exhaust tunnel ends, it will be level with the bottom of the cell like it should, and i know its gravity fed only, but i didn't know if this would affect how the fuel gets to it since when you launch and go everything is pushed towards the rear. I'm probably not analyzing every aspect of the pressure the fluid is putting on it self pushing out of the sump. I have a 150 degree fitting off the sump going towards back towards the front of the car 3 ft to where the the pump is going to be.
Old Dec 21, 2010 | 08:44 PM
locash's Avatar
Default Re: Sump to Pump location
As long as the fuel level in the tank is higher than the inlet to the pump, it would be gravity fed..
Old Dec 21, 2010 | 11:28 PM
MrParks's Avatar
matt you wont have a problem.
thunderboy
Jun 20, 2011 03:52 PM
Vegas H22Prelude Si
Oct 13, 2008 08:10 AM
ezark
Jun 10, 2006 12:41 PM
1 2 NV
Sep 4, 2002 12:44 PM
