Slick Size
I have a eg with 500+whp wieghing <2200lbs with driver. I will be taking it to the track in a couple weeks and would like to know what slick size I should run. I have a stock gear gsr w/mfactory lsd and new stock axles. The two tires I have are 24.5x9x13 or 25x8.7x13. I am trying to get in the 10's.
Yea either will work you are not going to see a huge difference with one or another. Although on your car you might find something that works better with one over the other just by luck haha. Like my car likes the m&h 25s a lot. So id say give those a shot.
i went 10.60 on stock axles with 25s..its all how you let the clutch out. 1.6 sixty foots too. those tires make you torn..wider yet not as tall..taller yet not as wide..Try them both! compare. in for results!
As long as your preload and launch right i see mid 10's easily, LOW 10's once launch control is on track and with the right driver. Looks like you need to raise the back end up a little more...
alteredautosports
Sep 9, 2004 02:58 PM
