slick size ?
Old May 14, 2010 | 04:20 PM
Old School CRX Swap's Avatar
Default slick size ?
getting ready to order slicks and dont want to do it twice
my question mh 23x8x13 or mh 24.5x8.5x13
last time at the track on bfg drag radials 225 50 15 i was trapping 116 bouncing off the rev limiter about 5 times 97 jdm itr tranny stock block usdm gsr turbo made 330 whp 220 trq on a mustang dyno in an eg hatch weighing 2250 with no one in it
according to the honda tranny calculator 4th gear rev to 8200 on 23s max speed is 115
on 24.5 is 122
the car is about 250lbs lighter than last time at the track and later im planning on doing a race gas tune shooting for around 400whp
thanks in advance
Old May 14, 2010 | 05:57 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: slick size ?
how bad were you spinning the dr's? when they spin you make the track longer. with that power i would use 23's
if you are goin after 400whp on fuel, then go with the 24.5's
Old May 14, 2010 | 06:36 PM
the dr's hooked in third i was keepin out of the throttle 1st and 2nd to keep from spinning to much
my thought on the 24.5's is gearing at the end due to the low geared tranny
Old May 15, 2010 | 11:43 AM
Mr. Em1's Avatar
your best bet would be to go with the 24.5 for two reasons, one you plan on upgrading power and the 24.5's will be better for that and two being able to gain a few more mph will benefit you so you dont have to shift into 5th
KevronsEG
Oct 3, 2007 03:06 AM
See Are X
Feb 19, 2007 07:22 AM
JDM97R
Apr 18, 2006 12:05 PM
EH2LS
Sep 8, 2003 02:15 PM
