Slick size!!! help please...
Old Apr 18, 2006 | 04:06 AM
JDM97R's Avatar
Default Slick size!!! help please...
Hi guys,
Recently I have put a B18C turbo into a civic ef.
The engine has about 360whp and with a jdm 98 spec tranny.
Now i use slicks m/h 24.5/8/15 and i have till second gear spinning at the drag strip,and did ET 11.1 with 1.91 60" .I have also the skunk 2 drag launch. I have a set of m/h 26/8.5/15 and was going to try them.Btw , i cross the line in fifth gear.
What do you think guys? should i try the bigger slicks?
The car +driver weights about 1050kg.
Thanks guys
Old Apr 18, 2006 | 07:51 AM
JDM97R's Avatar
Default Re: Slick size!!! help please... (JDM97R)
Anyone please
Old Apr 18, 2006 | 08:53 AM
nerdsports's Avatar
if it's an ITR tranny, it would explain why you're going into 5th gear through the 1/4 mile mark.
correct me if i'm wrong...
Old Apr 18, 2006 | 09:09 AM
aj99si's Avatar
Default Re: (nerdsports)
with the type r tranny I would try the 26's that way you will not have to shift into 5th. I think 25's would be better but if you have the 26's I would use them.
Old Apr 18, 2006 | 09:26 AM
Fitti's Avatar
If your head is built then you should raise the rev limiter on the car. I think most guys on here are around 9200k-9500K and that's being conservative. A 1.9 on that size slick and with that WHP level seems a little odd.
Good time though
What kind of air pressure are you running in your slicks?
Old Apr 18, 2006 | 10:03 AM
crxh22a4's Avatar
Default Re: (Fitti)
How old are the slicks 24.5 should be right for your setup, what psi are you running?
Old Apr 18, 2006 | 11:33 AM
JDM97R's Avatar
Default Re: (crxh22a4)
They are about 5 months old and i keep them 10 psi
Old Apr 18, 2006 | 11:58 AM
Fitti's Avatar
Default Re: (JDM97R)
you need to drop the pressure in those slick. 10 pis and the side walls probably aren't even wrinkling. Try 6-7 psi cold and see if that helps you out any. Also where is your redline set at?
Old Apr 18, 2006 | 12:05 PM
JDM97R's Avatar
Default Re: (Fitti)
My red line is 8600
93egSLEEPER
Jul 22, 2009 07:31 PM
jasperjohn
Feb 4, 2009 08:47 AM
See Are X
Sep 14, 2008 12:40 AM
JDM97R
Apr 20, 2006 02:45 PM
paulzy
Jul 6, 2002 06:23 PM
